Im not comfortable using the autothority's variable resistor that is hard wired into their maf system.
does anyone know the BOSCH part number for an air temp sensor that will work with the DME. or otherwise replace the stock temp sensor in the AFM? I have been searching for this part number for days. the only thing i can come up with is the Bosch Temp. Sensor #0 280 130 039 I have a porsche 944 turbo with a list of mods in my signature block
87 951 = home made MBC, Large Turbo, Autothority MAF, Mafterburner, custom fuel system w. 55lb injectors, 951MAX chips, water/mentanol injection, 2-stage Nitrous injection, punched out cat, Magnaflow muffler. 944's are like kids, the average owner has 2.5. |
This is the spec for the NTC thermistor in the temp sensor if you can get one that matches the relevant part -30 C to 80 C you can use it.
Sox R25 3.3 k ohm +/- 5 % B(25/50) 3950 K +/- 3 % TEMP. R-low R-center R-high (deg.C) (k ohm) (k ohm) (k ohm) -40 97.3324 113.9407 133.0495 -39 91.1782 106.5210 124.1344 -38 85.4553 99.6352 115.8774 -37 80.1307 93.2413 108.2257 -36 75.1740 87.3011 101.1309 -35 70.5575 81.7793 94.5489 -34 66.2556 76.6439 88.4394 -33 62.2447 71.8653 82.7654 -32 58.5035 67.4164 77.4930 -31 55.0120 63.2724 72.5914 -30 51.7519 59.4105 68.0320 -29 48.7065 55.8097 63.7889 -28 45.8603 52.4506 59.8380 -27 43.1990 49.3156 56.1575 -26 40.7095 46.3883 52.7272 -25 38.3795 43.6537 49.5285 -24 36.1932 41.0923 46.5380 -23 34.1456 38.6978 43.7473 -22 32.2272 36.4583 41.1419 -21 30.4288 34.3628 38.7084 -20 28.7424 32.4012 36.4344 -19 27.1602 30.5640 34.3084 -18 25.6752 28.8427 32.3199 -17 24.2807 27.2291 30.4592 -16 22.9708 25.7160 28.7173 -15 21.7398 24.2965 27.0859 -14 20.5825 22.9641 25.5573 -13 19.4940 21.7132 24.1245 -12 18.4698 20.5380 22.7808 -11 17.5057 19.4338 21.5203 -10 16.5979 18.3956 20.3372 -9 15.7427 17.4193 19.2263 -8 14.9368 16.5008 18.1829 -7 14.1771 15.6362 17.2024 -6 13.4605 14.8221 16.2807 -5 12.7846 14.0554 15.4138 -4 12.1457 13.3319 14.5973 -3 11.5427 12.6500 13.8288 -2 10.9732 12.0071 13.1055 -1 10.4352 11.4007 12.4243 0 9.9269 10.8286 11.7826 1 9.4469 10.2892 11.1786 2 8.9929 9.7798 10.6090 3 8.5633 9.2986 10.0717 4 8.1568 8.8438 9.5648 5 7.7719 8.4140 9.0863 6 7.4068 8.0067 8.6336 7 7.0609 7.6216 8.2061 8 6.7333 7.2572 7.8024 9 6.4227 6.9124 7.4208 10 6.1283 6.5860 7.0602 11 5.8493 6.2771 6.7193 12 5.5846 5.9845 6.3969 13 5.3334 5.7071 6.0918 14 5.0949 5.4442 5.8029 15 4.8684 5.1949 5.5294 16 4.6532 4.9583 5.2702 17 4.4487 4.7338 5.0245 18 4.2543 4.5207 4.7918 19 4.0695 4.3184 4.5711 20 3.8938 4.1263 4.3618 21 3.7267 3.9439 4.1633 22 3.5677 3.7705 3.9749 23 3.4163 3.6057 3.7961 24 3.2722 3.4490 3.6263 25 3.1350 3.3000 3.4650 26 2.9964 3.1582 3.3205 27 2.8646 3.0233 3.1829 28 2.7394 2.8950 3.0517 29 2.6203 2.7727 2.9266 30 2.5071 2.6563 2.8073 31 2.3994 2.5454 2.6936 32 2.2969 2.4398 2.5851 33 2.1993 2.3391 2.4815 34 2.1064 2.2431 2.3827 35 2.0179 2.1516 2.2883 36 1.9337 2.0643 2.1982 37 1.8533 1.9810 2.1121 38 1.7768 1.9015 2.0299 39 1.7038 1.8256 1.9513 40 1.6342 1.7532 1.8761 41 1.5678 1.6840 1.8043 42 1.5045 1.6179 1.7355 43 1.4441 1.5548 1.6698 44 1.3864 1.4944 1.6069 45 1.3313 1.4367 1.5467 46 1.2787 1.3816 1.4891 47 1.2285 1.3289 1.4340 48 1.1805 1.2785 1.3812 49 1.1347 1.2303 1.3306 50 1.0908 1.1841 1.2821 51 1.0489 1.1399 1.2357 52 1.0088 1.0976 1.1912 53 0.9705 1.0571 1.1485 54 0.9338 1.0182 1.1075 55 0.8987 0.9811 1.0683 56 0.8651 0.9454 1.0306 57 0.8329 0.9112 0.9945 58 0.8021 0.8785 0.9598 59 0.7725 0.8471 0.9264 60 0.7442 0.8169 0.8945 61 0.7172 0.7881 0.8638 62 0.6912 0.7604 0.8343 63 0.6664 0.7338 0.8060 64 0.6425 0.7083 0.7789 65 0.6197 0.6838 0.7527 66 0.5977 0.6602 0.7275 67 0.5766 0.6376 0.7033 68 0.5563 0.6158 0.6800 69 0.5369 0.5949 0.6576 70 0.5182 0.5748 0.6360 71 0.5003 0.5556 0.6154 72 0.4832 0.5371 0.5955 73 0.4668 0.5193 0.5764 74 0.4509 0.5022 0.5580 75 0.4357 0.4858 0.5403 76 0.4211 0.4699 0.5231 77 0.4070 0.4547 0.5066 78 0.3934 0.4400 0.4907 79 0.3804 0.4258 0.4754 80 0.3679 0.4122 0.4606 81 0.3558 0.3991 0.4464 82 0.3443 0.3865 0.4327 83 0.3331 0.3743 0.4195 84 0.3224 0.3626 0.4068 85 0.3121 0.3513 0.3945 86 0.3021 0.3404 0.3827 87 0.2925 0.3300 0.3712 88 0.2833 0.3198 0.3602 89 0.2744 0.3101 0.3495 90 0.2658 0.3007 0.3392 91 0.2576 0.2916 0.3293 92 0.2496 0.2828 0.3197 93 0.2419 0.2744 0.3104 94 0.2345 0.2662 0.3014 95 0.2273 0.2583 0.2928 96 0.2205 0.2507 0.2844 97 0.2138 0.2434 0.2764 98 0.2074 0.2363 0.2686 99 0.2013 0.2295 0.2610 100 0.1953 0.2229 0.2538 101 0.1896 0.2165 0.2467 102 0.1840 0.2104 0.2399 103 0.1786 0.2044 0.2333 104 0.1734 0.1986 0.2269 105 0.1684 0.1930 0.2207 106 0.1636 0.1876 0.2147 107 0.1589 0.1824 0.2089 108 0.1544 0.1774 0.2033 109 0.1500 0.1725 0.1979 110 0.1458 0.1678 0.1926 111 0.1417 0.1632 0.1875 112 0.1377 0.1588 0.1826 113 0.1339 0.1545 0.1778 114 0.1302 0.1503 0.1732 115 0.1266 0.1463 0.1687 116 0.1231 0.1424 0.1643 117 0.1198 0.1387 0.1601 118 0.1165 0.1350 0.1560 119 0.1134 0.1315 0.1521 120 0.1104 0.1281 0.1483 121 0.1074 0.1248 0.1445 122 0.1046 0.1216 0.1409 123 0.1018 0.1184 0.1374 124 0.0992 0.1154 0.1340 125 0.0966 0.1125 0.1307
"Little problems always come back and bring bigger friends with them". 1986 951"MADDOG" black Dual port WG, 4 port control valve with EBC |
Super Moderator
sox you have too much time on your hands. go drink a beer.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
Thats when I do my best work Nize
![]() Actually tequila is my brain booster of choice. Sox
Super Moderator
have you tried tarantula azul? it's pretty good.
Tequila made in Italy ?? actually I have, its good but I like straight stuff without the citrus flavor. I like Herradura Tequila (anejo reposado) and Milagro for sipping.
Sox
