Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
What is this part called?
The hose that would run from the Banjo bolt on the intercooler pipe into the Lindsey Boost Enhancer (or wastegate tube - i think - on stock cars).
In stock form, it is a hose that is rubber on the inside, with a cloth-like outer coating.
What is this part called? And is it possible to order a replacement? Mine is split and I currently have a larger-diameter hose around it and clamped down...
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 07-09-2007, 12:36 PM
You can order that kind of hose in bulk in many different diameters. I just cant remember where I saw it. It was either Pelican parts or performance Products: ***************
Old 07-09-2007, 01:23 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Runs from Banjo bolt to CV (or MBC/EBC & wastegate on modded cars).
Standard flexible rubber fuel hose works fine. Forget the exact size, but 3/16" I.D. seems to come to mind. I'll check my car tonight and see what I've got on there.
Black Cars Matter
Old 07-09-2007, 04:44 PM
soxnail's Avatar
3/16 " I.D fuel hose works fine..
Sox
"Little problems always come back and bring bigger friends with them".
1986 951"MADDOG" black
Dual port WG, 4 port control valve with EBC
Old 07-09-2007, 07:12 PM
Writer/Teacher
CJFusco's Avatar
Without taking the hose assembly apart, how does it attach to the banjo bolt? It looks like it runs inside the bolt housing...
Old 07-12-2007, 07:15 AM
soxnail's Avatar
Here are two pics one from the manual and other of fuel hose and clamp to replace the original.
Sox
Old 07-12-2007, 09:14 AM
any vac hose will do. I replaced mine with some industrial strength vac hose designed to hold a couple hundre psi
1986 Bmw 325 5spd (turbo)
2002 Nissan Spec V 6spd (for Sale PM me!)
2001 Honda Civic
1986 Porsche 951 5spd Guards Red
(Stage 1, w/ 89 Turbo S Lsd Trans!)
Old 07-12-2007, 11:25 AM
soxnail's Avatar
sorry the pics did not post.
Sox
Old 07-12-2007, 05:11 PM
Super Moderator
nize's Avatar
the connector where the hose attaches to the banjo itself is deceiving, because it looks like the metal banjo part and the metal collar on the hose is all one piece. in reality, the metal collar on the hose is just a fancy hose clamp that appears smooth like a metal collar. to get that off i used some pliers and a lot of muscle to peel the metal off. you could use a dremel to cut that clamp/collar off just as easily. be careful not to cut into the banjo inside, though.
the easiest way to replace the hose itself (and a great upgrade) is to use the silicone tubing from lindsey racing, which looks like the red tube in the photo above.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 07-17-2007, 10:51 AM
What you do is you can take tin snips cut around the out side of that collar clamp it to a vise clap and roll it right off. Underneith is just a regular sized barbed fitting that you can attach any hose to
2001 Honda Civic
Old 07-17-2007, 11:21 AM
Super Moderator
nize's Avatar
here's the link to the silicone hoses;
http://tinyurl.com/ysht7a
Old 07-17-2007, 12:15 PM
