Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
fast924S's Avatar
Send a message via AIM to fast924S
Using the LR mafterburner
Hey guys, I will be installing a MAfterburner from LR on my 1987 924S that has a huntley racing MAF kit with the 4 knob tuner. I just wanted to see if any of you have used the Mafterburner and how you like it. Was it hard to tune?? Was it hard to install?? I will also be using a wibeband 02 sensor for easy tuning. Do you guys recommend the Mafterburner?
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 10-22-2007, 05:12 PM
um whats a mafterburner do by itself
88 928 S4 Black, Black and Grey Interior
Alpine head unit & amp, Bazooka Tube, Viper 5704 Smart Start GPS tracking, Devek Headers, Flowmaster 40 3" with Resonator, Auto Authority chips. Custom Luggage Cover.
Traded - 86 944 Turbo Guards Red. RIP - 85.5 944 Guards Red
Old 10-23-2007, 05:27 AM
fast924S's Avatar
A mafterburner is a product from LR, Its a piggy back digitial fuel controler and data logger. Moslty used for people who have switched over from the AFM to MAF, Thats why I posted over here cuz most of the 951 performance guys go MAF.
Link to more info
http://www.lindseyracing.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=LR&Category_Co de=944MAFTERBURNER
Old 10-23-2007, 12:21 PM
Super Moderator
nize's Avatar
i know three local guys using the lindsey maf with mafterburner. they seem to like it.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 10-23-2007, 05:19 PM
fast924S's Avatar
Cool, Im excited to get it and start tuning
Old 10-23-2007, 05:46 PM
Engine swap pro
myskyon's Avatar
i have been running mine for allmost 2 years now and i love it. its easy to tune and easy to wire up using the stock wires. it gives you enough controll to tune with the stock narrow band sensor. as i have done. and still do.
87 951 ---- "R2" - under the knife
87 951 ---- "R1" Parting out - Gave to a good friend
88 951 ---- Black one - recieved as a trade for my 87 - very mint - parting out
06 WRX ---- The "RUE"
Old 10-26-2007, 12:38 PM
fast924S's Avatar
COOL, I have a wideband to use with it. I was reading the install directions that I downloaded from LR and do you know what the eec harness is?? AT tleast I think thats what the call it. Also any pointers on install and tuning
Old 10-26-2007, 12:46 PM
Engine swap pro
myskyon's Avatar
eec? i have no idea. i just helped a buddy of mine by giving him a piece of mind by showing him witch wires to splice off of. it is very simple. just take your time and double check before you splice. you can use what LR sends you (its what i have used) or you can cut and solder the wires then heat shrink them. now when you get to the point of needing to find a power wire for the MAF its self run the wire up to the test port on the drivers side and take out the test port then find the black wire and splice off of that.
as for the mafterburrner box its self just follow the directions. and you can take apart the DME plug very easly. just remove the plug from both the DME and KLR and on both you will see a screw ( on the Plug connectors them selves) remove the screw but to not loose it. The DME plug "slides" apart. The KLR plug you have to push the wire through the plug. and they both have markings for the pins. also you will have to roll back the rubber boost at the ends of the connectors. if I have confused you please let me know and i will upload some pictures for you.
Old 10-26-2007, 05:01 PM
Engine swap pro
myskyon's Avatar
Pictures time yes i have them all horay!!!! here you go i will also see if dave will include these with his instructions. these pictures are not in any order. but just add this to my last post and it will make sence. also if you dont know the large bage plug in the DME and the smaller black one is the KLR.
Old 10-28-2007, 09:34 AM
fast924S's Avatar
Cool, Thanx for all the info, Thing Is Im installing it into a 87 924S with a Huntley Racing MAF and 4 knob tuner, I wanted something better then the 4 knob tuner so I picked up a USED LR mafterburner
Old 10-28-2007, 10:16 AM
Engine swap pro
myskyon's Avatar
oh damn i didnt notice that it was going into a 924S. i am sorry. the orange wire is just a TPS sensor pick up for the mafterburrner. i do not know what pin that would be on the 924 nor do i know what the wire colors are. i bet you could find them via the shop books.
Old 10-28-2007, 12:43 PM
