Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Anyone use this WBO2 kit?
http://cgi.ebay.com/ebaymotors/PLX-DM-5-SM-AFR-Wideband-Air-Fuel-Ratio-O2-Sensor-kit_W0QQcmdZViewItemQQcategoryZ107063QQihZ006QQite mZ160193029508QQtcZphoto
Is this any good? Anyone using this? Feedback good or bad?
Thanks!
-- Jim
1983 944
Old 12-25-2007, 10:30 AM
Super Moderator
nize's Avatar
there are some guys using the PLX wideband gauge over on rennlist. personally, i think the PLX face looks kind of cheap because they use the round LED's instead of the rectangular ones and for that price i'd rather get the innovate LM-1;
http://www.strippermotorsports.com/innovate1.html?gclid=CIXboti3xJACFQF7aAodwwR1WQ
or the aem uego wideband;
http://www.turbowholesale.com/product.php?productid=4926&cat=0&page=1&gclid=CPmk k623xJACFQbMXgodz3VRPA
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 12-25-2007, 01:02 PM
Super Moderator
nize's Avatar
you might also be interested in reading this review;
http://www.fordmuscle.com/archives/2007/06/WidebandShootout/index.php
i'll save you some time. the innovate lm-1 wins.
Old 12-25-2007, 01:09 PM
I'm new to this tuning stuff, so I am trying to keep this as simple as possible.
Basically, I have a stock engine and looking to mod with:
tial 38mm wastegate
adj. FPR
black knob boost controller
951 Maxx chips
And I want to utilize a WBO2 sensor to monitor things. If I use a standalone WBO2 sensor and gauge, can I adjust fuel with an adjustable fuel pressure regulator if the O2 ratio is out of spec? Would that work as a solution to monitoring and adjusting a/f ratios?
edit: And I'd like to be able to monitor a/f ratios while on track, not just on a dyno.
-- Jim
1983 944
Old 12-25-2007, 03:16 PM
Super Moderator
nize's Avatar
adjusting afr using an adjustable fpr is very kludgy and inaccurate. for example, you couldn't adjust afr between, say 4500 and 5000 rpm without affecting the entire rpm range.
instead of getting the 951 maxx chips, why not just get the maxhp tuning solution? this will allow you to datalog as well as tune afr more precisely (by controlling the fuel injectors directly) than an adjustable fpr would allow.
Old 12-25-2007, 04:35 PM
So excuse my stupidity, but I am new to this tuning thing as well. What is the optimum air fuel mixture for street/track use. Also, I have seen these gauges in action...what do the lights mean exactly...in other words, when the lights circle around what exactly is happening with the air fuel mixture?
Like i said, please excuse my stupidity on this topic.
Old 12-25-2007, 07:30 PM
Super Moderator
nize's Avatar
sounds like you've got a lot of reading to do. this will help start you out;
afr;
http://en.wikipedia.org/wiki/Air-fuel_ratio
afr meter;
http://en.wikipedia.org/wiki/Air-fuel_ratio_meter
wideband o2 sensor;
http://en.wikipedia.org/wiki/Wideband_O2
general tuning tips and primer;
http://www.angelfire.com/pro2/rst/air_fuel_tuning_tips.htm
more simplified tuning primer;
http://www.carcraft.com/techarticles/116_0402_innovate_air_fuel_ratio_meter/index.html
Old 12-25-2007, 09:10 PM
Keithr726's Avatar
Send a message via AIM to Keithr726
I have a Lc-1 and XD-16 gauge that I'm installing now. I was thinking about the AEM (similarly to the PLX) and chose the Lc-1 for its better features and quality. I too have heard good things on rennlist but by far is zeitronix which I would have bought if only they offered a gauge at that time, they do now.
http://www.zeitronix.com/Products/ZR-1/ZR-1.htm
Keith
1986 Porsche 951
Old 12-25-2007, 09:22 PM
Super Moderator
nize's Avatar
yeah, the zeitronix is the best, but at $400 it's not cheap anymore.
Old 12-26-2007, 09:18 AM
That Guy
Techno Duck's Avatar
I have the Innovate LC-1 and XD-16 gauge as well. And if i had known if they sold the Zeitronix with a gauge now i would have bought that! But they are very close in price and have what look to be the exact same design of gauge.
I never liked the display of the older Zeitronix, i prefer to have a analog (though its really LED's) as you can quickly glance at the gauge to see where its at rather than focusing on the display.
But one of my friends has been running the Innovate setup for quiet a while on his heavily modified WRX and loves it. One of the nice features of the Innovate setup that im not sure the Zeitronix has is a record feature that will play back its readings. Mind you its not actually datalogging to a computer file, just a record and playback feature. It does have data logging capabilities though you need to buy the LMA3 box to use that feature.
Really the nice thing about the Zeitronix setup is plenty of people have wired it up to the 944's electronics, so there isnt much question as to how to do it. You might have to do some experimentation using the Innovate system.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 12-26-2007, 05:28 PM
