Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
ERAU944's Avatar
Send a message via AIM to ERAU944
Thumbs down all of a sudden only boosting to 1.5 bar
on my way home today, the 951S only would boost to about 1.5 bar. the car is stock, with the exception of the bypass valve (which has been fine also, i just replaced it a few months ago). other than that, the car runs normally and sounds just fine, it's just down on power and it's only building about 1/2 a bar of boost.
any help would be appreciated!
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme
'88 951S - zermatt silber/black - staying stock. purchased in 11-2006
'84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001
2021 Tesla Y - to get me to work
Old 12-14-2007, 12:07 PM
winter-hater club member
nynor's Avatar
how far up the stock gauge does the boost needle go? could be going into limp home mode, or you have a major boost/vacuum leak.
"COOL PRIUS!" - Nobody Ever
Old 12-14-2007, 03:23 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
"limp home mode".
Or a plugged cat.
Or a boost leak (check the clamps at the intercooler & intake).
Do you know the procedure using an LED on the test port to determine limp-home mode codes? I can dig it up if you need it.
Black Cars Matter
Old 12-14-2007, 04:23 PM
ae1969's Avatar
Send a message via ICQ to ae1969
or the impellers on the compressor side are mangled to bits.............
That is such an uplifting thought.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 12-14-2007, 06:54 PM
ERAU944's Avatar
alex - that thought makes me queasy!
i doubt that's it though.
i'm thinking it's a vacuum/boost leak - although i'm not certain. i took the air line off the bypass valve to test its operation (works fine), and drove it again - same thing. after that i noticed the vac line i had just moved was disconnected at the T near the fuel rail. i didn't get to test it again however, it'll have to wait 'till tomorrow.
thanks for the replies, i'll let y'all know what happened.
Mike
Old 12-14-2007, 07:11 PM
ERAU944's Avatar
p.s. i doubt it's limp-home mode, my roommate's old '87 hit that a couple times when he had some overboost issues with chips he was running. the car builds boost, just not what it should.
soxnail's Avatar
If you are getting 0.5 bar boost then the car will not display any "codes". Normally in limp mode the car only has 0.2 bar. That said if you are using the car's gauge to see the boost it may be hard to tell what its showing.
The first thing I would look at is exhaust leak/block preventing the turbo from spooling up. Of course I assume that you have done the "pinch line" test to see if the car makes proper boost or not. If it makes proper boost with the line to the wg pinched off then ignore my comment about the exhaust.
Sox
"Little problems always come back and bring bigger friends with them".
1986 951"MADDOG" black
Dual port WG, 4 port control valve with EBC
Old 12-15-2007, 10:19 AM
nynor's Avatar
when my car shows 1.5 on the stock guage, it is building a little over 10PSI, which (i believe) has been validated as normal for this altitude. this is also within stock boost range. the boost range for the S model is the same for the non-S, it just holds it to red-line.
Old 12-15-2007, 10:31 AM
Luis de Prat's Avatar
Hey Mike, it's been a while!
What about your cycling valve? Ever replaced it? Maybe it's leaking or not working right?
Nice seeing you again.
Old 12-15-2007, 12:04 PM
The 'y' you speak of also handles positive pressure that holds the bypass valve shut. Nice easy fix if that is the problem. There is another 'y' near the cycling valve.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 12-16-2007, 04:15 AM
Super Moderator
nize's Avatar
if the cycling valve fails, it will fail in 'open' mode, which would result in the same symptoms as cripple mode, making only .2bar of boost (1.2 on the stock gauge).
is your car stock? do you have LBE, banjo restrictor jets, or any other boost mod? what chips are you running?
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 12-16-2007, 03:33 PM
ERAU944's Avatar
Thumbs up must've been the T
i pity the fool!
well, today i FINALLY took the car back out of the garage. the weather's been decent enough to ride almost every day since i posted the question. it looks like the tube that had come out by the damper was the culprit, the car drives normally now.
Luis! good to see you again too, it's definitely been awhile. i think last time we exchanged PMs it was on rennlist... haven't been there since. in fact, i had just replaced the cycling valve, and maybe that's why the hose worked loose (from me monkeying around with the line). at any rate, good to see you again, if you ever need anything and you're in south florida, look me up! Email works best for me, i rarely check PMs, or the board. the motorcycles are just too fun to ride, and too fuel efficient to drive much anymore. hopefully that'll help me save up for some track time.
Mike
Old 01-23-2008, 11:20 AM
ERAU944's Avatar
btw, nize, the car is completely stock, barring some exhaust leaks that one day i'll get to deal with
Old 01-23-2008, 11:22 AM
