Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Speed and reference sensors
Son is at the shop replacing the clutch. Almost has it all back together. Forgot which is the speed sensor and which is the reference sensor cable. Do not have a wiring diagram. How do we tell which is which?
Old 06-24-2008, 06:36 PM
Spidey944's Avatar
Send a message via MSN to Spidey944 Send a message via Yahoo to Spidey944
They are both the same. If it wont start one way, just switch them at the connector end. what matters is the depth you set the sensors at. If you have no tach bounce during start up, they are prob. backwards.
Doug 86 951
BBS, LSD, MBC, Zeitronix stuff, Rennbay stuff, Pelican stuff, Arneworx stuff, and stuff with more stuff.
Old 06-24-2008, 06:56 PM
OK thanks that really helps. Passed it on. Started this last week and had to stop due to ordering a pressure plate. Hopefully he will get all but the rear end back together tonight.
Old 06-24-2008, 07:18 PM
Super Moderator
nize's Avatar
what pressure plate did you use?
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 06-25-2008, 02:16 PM
Used sachs. And pulled a dummy move and put the PP on, torqued it down, and then stood back and went "DOH! I forgot to put on the starter ring!"
'86 951 Guards Red, MBC, Adjustable FPR, Venturi Delete, LR Exhaust
Old 06-25-2008, 03:09 PM
