Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Turn Signal Problems
I am having trouble with my turn signals. They function normally when the parking and head lights are not on. They don't work when those lights are illuminated. The problem began after I changed bulbs in the front parking lights. I thought they might have been loose and that seemed to be the case as the lights were very sporadic in their operation. They are no longer loose. Any ideas what could cause this problem. Bad Relay? Is there any way to check this before I buy another. Other suggestions?
'87 951
Old 10-14-2008, 04:23 AM
In the Fires of Hell.....
kdjones2000's Avatar
It might be that the new bulbs are a different wattage, and when your lights are on with the drain on the electrical system the blinker is not going off.
Check to make sure that you have the correct bulbs in there, and maybe that's your issue.
Good luck,
Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 10-14-2008, 08:29 AM
Super Moderator
nize's Avatar
i also vote that the new bulb is a different wattage, vampiring power from the rest of the system.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 10-14-2008, 04:15 PM
Send a message via ICQ to bud9344 Send a message via AIM to bud9344
Check ground connection on the light socket.
Bud
Old 10-15-2008, 04:48 AM
