Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Exhaust Questions - Cat Delete & Exhaust Temperature Sensor?
Hi Guys,
I'm hoping to install a Fabspeed cat-bypass downpipe and cat-back over the winter. The car is otherwise stock, so what do I do with oxy sensor? Looks like the Fabspeed setup does not have a bung welded in to place the oxy sensor. Should I just weld one in myself?
Chrenan
1987 951 ROW
Old 10-28-2008, 03:42 PM
That Guy
Techno Duck's Avatar
The oxygen sensor is actually in the crossover up pipe (turbo inlet). So you would not be replacing that with the FabSpeed cat-bypass.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 10-28-2008, 05:21 PM
You are totally correct, my bad, noob mistake.
I have another sensor about halfway down the exhaust system, PET calls it a temperature sensor and it is marked as (J) for Japan only. My car was imported to Canada from Japan.
Any idea if this sensor actually influences the running condition of the car, or does it only trigger a warning light?
1987 951 ROW
Old 10-29-2008, 07:03 AM
