Exhaust Questions - Cat Delete & Exhaust Temperature Sensor?
Hi Guys,
I'm hoping to install a Fabspeed cat-bypass downpipe and cat-back over the winter. The car is otherwise stock, so what do I do with oxy sensor? Looks like the Fabspeed setup does not have a bung welded in to place the oxy sensor. Should I just weld one in myself? Chrenan
1987 951 ROW Last edited by chrenan; 10-29-2008 at 07:04 AM.. |
That Guy
The oxygen sensor is actually in the crossover up pipe (turbo inlet). So you would not be replacing that with the FabSpeed cat-bypass.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
You are totally correct, my bad, noob mistake.
I have another sensor about halfway down the exhaust system, PET calls it a temperature sensor and it is marked as (J) for Japan only. My car was imported to Canada from Japan. Any idea if this sensor actually influences the running condition of the car, or does it only trigger a warning light?
1987 951 ROW |
