high idle question
I have a 1987 951 that normally idles at a normal rpm. Every once in a while it idles at around 2000 rpm though. It tends to do that for a random amount of time and only when the car has been warmed up. I thought it could be a sensor that is not working right but i am not sure. Any input as to what it could be would be a huge help.
Thanks |
In the Fires of Hell.....
I noticed on mine that when the TPS is not connected the car will idle at a higher RPM, for me around 1600.
Check your connections there as a start. Good luck, Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
Tags |
944 , 951 , idle , porsche , turbo |
