quieting rear hatch rattle
So the rear hatch rattles worse than a tinker's mule cart. Everything--pins, latch, etc.--is tight. What have you all done to quiet that rattle? I could use some foam tape, but I'm looking for something less trailer park.
Super Moderator
the glass is probably separating from the metal frame edge. the only way to fix this is to re-glue the glass back to the frame.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
glass seems tight--at least I can't find anything loose. Any thing else to look for before I caulk the whole thing shut (kidding--but I'd love less rattle.)
In the Fires of Hell.....
Replacing the weatherstripping had benn known to help.
I have also found that waxing the weatherstripping, or putting some kind of conditioner on it, has reduced the noise somewhat. Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
