Super Moderator
replacement hatch struts
i remember weltmeister used to make replacement hatch struts and hood struts for the 944 that came with lifetime warranty. i have a set of these in stainless for the hood, but can not find any for the rear hatch.
does anyone know if these are still available? i think i recall having to buy them from paragon products, or automotion. they certainly still make them; http://www.weltmeister.com/ProductDetails.aspx?productID=424 i guess i'll try calling weltmeister directly tomorrow and get more info; 800-588-7448
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
Super Moderator
info on the stock replacement info (not weltmeister), available on pelican
944.511.351.01 gas-filled strut (front hood shock, either side) $15.25 944.512.348.00 gas-filled strut R (rear lid shock, right) $37.75 944.512.349.00 gas-filled strug L (rear lid shock, left) $31.25
Automotion has them. $29.99 each side.
http://www.***************/product.asp?pf_id=P908103&dept_id=4079 Or you can save a couple bucks and get a pair for $57.99. http://www.***************/product.asp?pf_id=P912362&dept_id=999
'88 944 Turbo S |
Super Moderator
those are the front hood struts. i'm looking for the rear hatch struts.
i just found out that pelican also has the weltmeister front hood struts for $29.99; http://www.pelicanparts.com/cgi-bin/ksearch/PEL_Search.cgi?please_wait=N&forumid=&threadid=&FI LTER_944M=ON&command=DWsearch&command=DWsearch&REF INE=Y&FORUM_REFER=&description=PEL-PP908103&x=0&y=0&FILTER_944M2=ON&description=944+5 12+348+00+&FILTER_944M=ON&FILTER_944M2=ON
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) Last edited by nize; 03-10-2009 at 09:41 AM.. |
Oops, should've read your first post more closely and I'd have seen that.
So, any luck when contacting Weltmeister?
'88 944 Turbo S |
