Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
ArthurPE's Avatar
first problem...
and thanks to you guys...a 5 minute solution
too much heat...
just felt down there, felt the loose drive rod, then no clip, and only 1/2 the 'pinch' bushing...
checked with a light...done
the dreaded 'heating clip'
ordered a couple with clips...among other stuff
secured with a tie wrap until they arrive...
this is why this place is great, one search and wham...problem solved...
thanks
Old 07-30-2009, 12:19 PM
ArthurPE's Avatar
second problem
hope they are all this easy...
idle started fluctuating...was stable...
did some searching...
idle adjusting screw...gone...lol
anybody know the thread pitch so I can plug it until I get the part?
Old 07-30-2009, 12:43 PM
In the Fires of Hell.....
kdjones2000's Avatar
I think I have one that you can have....
LMK, Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 07-30-2009, 03:23 PM
ArthurPE's Avatar
LMK, Keith
thnx, very generous but I already added 2 to my Pelican order...
if it's back ordered I may take you up on your offer, then I'll send you one when mine arrive...
I did a field expedient fix:
a plastic push nut, ~1.5" long, tight fit, 1/2" head...
put some foam tape on the underside of the head for sealing...
got car hot
inserted plug until I got ~800 rpm with AC and lights on...
goes to 1000 or so when AC and lights off...
then stabilizes ~900
feels fine, no stutter or stalling...
while messing around, pulled battery, cleaned tray, drain hole and all terminals including body ground...
the RS4 has sat for a week now...it's feeling jealous
Old 07-30-2009, 04:45 PM
ArthurPE's Avatar
problem 1 solved: new clip/bushing installed...very simple
waiting on idle screw, shipped today...
Old 08-05-2009, 03:57 PM
