Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
All Spooled Up
Is there a rising-rate FPR available?
I am considering a 3bar FPR, but it will make the car consume excess fuel, even when it is not needed. What I would strongly prefer is a rising-rate FPR with adjustable "offset" (the point at which the "rate" starts rising beyond linear, or 1:1). I have seen them for other turbo cars (such as the t-bird turbocoupe), but not for the cars in this forum. Does any1 know if they exist, and who makes them & who sells them?
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 08-29-2009, 06:18 AM
ArthurPE's Avatar
why would it use more gas?
Old 08-29-2009, 10:26 AM
All Spooled Up
Anytime the engine is running open-loop (like during warmup), where the O2 sensor cannot compensate for the increase in pressure, there will be an increase in flow, at any given pulse width. The only way for it to not use more fuel would be to write new fuel maps that are tailored to the higher pressure.
Old 08-29-2009, 02:14 PM
ArthurPE's Avatar
thanks...I hadn't considered the scenario with the lambda loop not controlling...
during warm-up, and full throttle?
http://www.custom-car.us/efi/fuel-pressure.aspx
Old 08-29-2009, 03:22 PM
All Spooled Up
[QUOTE=ArthurPE;4865861]thanks...I hadn't considered the scenario with the lambda loop not controlling...
Yes, also at full throttle, but that's when you want it to use more fuel! That's, ideally, the ONLY time you want it to use more fuel.
Old 08-29-2009, 06:05 PM
