Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
All Spooled Up
How low will it go, without lugging?
What is the lowest rpm that you are supposed to go (under load) on a 951?
The reason I ask, is that at anything under 2K, I get substantial vibes, like the car is lugging, unless I am VERY light on the pedal. I can run the 924S down to 1500 without experiencing this. Is this normal? Why the difference?
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 03-05-2010, 11:32 PM
bearone2's Avatar
depends if you're uphill/downhill/flat. uphill, i try to not get below 3k.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 03-06-2010, 02:21 AM
All Spooled Up
That is only because you are in to the pedal farther for flat vs down hill, and for uphill vs flat. I am talking about how low the 924S can go on flat vs how low the 951S can go on flat.
Old 03-06-2010, 06:42 AM
Super Moderator
nize's Avatar
when i'm tuning the car for WOT fuel map, i start out at full load at 1200rpm with no vibration problems.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 03-06-2010, 09:54 AM
Architect / Car Guy
carlege's Avatar
Send a message via AIM to carlege
What are your engine mounts looking like?
Looking Forward to getting my First "car" Porsche 951
Old 03-06-2010, 11:50 AM
All Spooled Up
I'll have to take a close look. What should I be looking for?
Old 03-06-2010, 12:36 PM
Architect / Car Guy
carlege's Avatar
they will look smooshed in the rubber part... almost flattened. and of course vibrating is one symptom
Old 03-06-2010, 12:45 PM
Had the same problem. Turns out my engine mounts had completely disintegrated. I'm looking forward to testing the car with the new mounts.
1990 944 T: 100 000 km/63K miles,
1997 986 2.5L: 95 000 km/60K miles,
Living in the trackless land of plenty!
Old 03-07-2010, 05:40 AM
All Spooled Up
Both of them? Not having checked them yet, it sounds likely that's what it is. I used to have a couple of them lying around. But since I have moved twice since then, I'll have to search to see if I still have them.
What's strange is that my 924S also has vibration issues, but they are of a completely different sort. At idle, you can feel the whole car shaking. But as soon as you touch the gas pedal, the vibes instantly vanish. Anyone ever had THAT symptom?
Old 03-07-2010, 06:56 AM
Yep. Both of them. Shorn clean off and had probably been that way for some time. They were completely dry, no oil left what so ever. Funny thing is I did not really notice it when driving or idling. The shaking was not bad at all. I assumed it was due to the lower compression of the turbo engine and a requirement of higher revs... I can't imagine how smooth it will be with the new mounts.
Old 03-07-2010, 07:42 AM
All Spooled Up
You know, I was attributing it the lower compression of the turbo engine too. But also the different intake runner geometry. With your response, as well an nize's, I've now put those thoughts to rest.
Old 03-07-2010, 07:57 AM
Az 944 Spec Director
M758's Avatar
I don't give it much throttle below 2000 rpm. The bigger problem is that car dis dog slow will that little rpm. I try to never go WOT below 2500 rpm. Seems like a waste.
Now my 8.0L V10 gas tow vehicle tows at 1600 rpm.
Joe P.
88 944 Turbo S - 100% Stock 84 - 944 Spec #94 Red/White
Arizona Region 944Spec Director
Az 944 Spec Champion 02/03, 2006 - 2nd Az Region 944 Spec 03,04,08,09
4th - 2009 NASA Natls - Fastest 944 spec lap at Miller Natls - 2.19.282 (Sat Warm-up)
Old 03-08-2010, 10:55 AM
