Can a 944na block be used in place of a 951 block?
Hello, I have a 1986 951 turbo car that I wanted to build a engine for. I have a extra 1986 944 na block and wanted to know what is different if any about the two, and if i would be able to use it? or any other information would be awesome!
Thank you, Steven |
Yes you can use 86 N/A block you will have to drill and tap left balance shaft housing for turbo oil feed line.
Ornery Bastard
The cylinder walls in the 951 block are strengthened (thicker) compared to the 944 N/A block and the 951 uses an external oil cooler as opposed to the 944 N/A's oil/coolant heat exchanger which is integral to the 944 N/A engine block.
Overall, I would not recommend using an N/A block as the base for a turbo engine. I'm sure that with enough time and money it would be possible, but it would be easier and much cheaper to use a proper 951 block.
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) |
winter-hater club member
are you sure they are thicker? two pictures: first is the turbo, second is my '83
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
Ornery Bastard
Clark's Garage says thicker, so that's what I went with. Haven't been inside one to put a micrometer on the cylinder walls myself though.
neither have i. you could be right, along with clark's. i'd never heard that before and didn't remember reading it on clark's page.
Ornery Bastard
It's kind of buried in the 944 Turbo FAQ on Clark's (italics added because it's easy to skip over):
The original '86 blocks are the same as NA. You would have to drill and tap the BS cover and simply bolt on the oil filter console/t-stat housing. It wasn't until later that the reinforced case was introduced.
Don Weaver-EBS Racing don@ebsracing.com 2006 Cayman S '86 944T '00 Boxster with EBS Racing 3.4 liter engine |
Thank you Guys, I'm think I will just look for a turbo block. I think it will be less complex if stay with turbo parts..
Thank you for all your info on this matter! Steven |
get a late block, then. '88 or later, is my suggestion.
