Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Can a 944na block be used in place of a 951 block?
Hello, I have a 1986 951 turbo car that I wanted to build a engine for. I have a extra 1986 944 na block and wanted to know what is different if any about the two, and if i would be able to use it? or any other information would be awesome!
Thank you,
Steven
Old 05-02-2010, 01:04 PM
Yes you can use 86 N/A block you will have to drill and tap left balance shaft housing for turbo oil feed line.
Old 05-02-2010, 03:17 PM
Ornery Bastard
The cylinder walls in the 951 block are strengthened (thicker) compared to the 944 N/A block and the 951 uses an external oil cooler as opposed to the 944 N/A's oil/coolant heat exchanger which is integral to the 944 N/A engine block.
Overall, I would not recommend using an N/A block as the base for a turbo engine. I'm sure that with enough time and money it would be possible, but it would be easier and much cheaper to use a proper 951 block.
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 05-03-2010, 06:31 PM
winter-hater club member
nynor's Avatar
are you sure they are thicker? two pictures: first is the turbo, second is my '83
"COOL PRIUS!" - Nobody Ever
Old 05-03-2010, 07:22 PM
Ornery Bastard
Clark's Garage says thicker, so that's what I went with. Haven't been inside one to put a micrometer on the cylinder walls myself though.
Old 05-03-2010, 08:43 PM
nynor's Avatar
neither have i. you could be right, along with clark's. i'd never heard that before and didn't remember reading it on clark's page.
Old 05-03-2010, 08:44 PM
Ornery Bastard
It's kind of buried in the 944 Turbo FAQ on Clark's (italics added because it's easy to skip over):
Because of the increase in engine performance, the engine also received thicker cylinder walls, forged pistons, a larger oil pump, and heavier head gasket. 944 Turbos were also equipped with an external oil cooler as opposed to the normally aspirated cars whose cooler is integral to the block.
Old 05-03-2010, 10:13 PM
EBS_Don's Avatar
The original '86 blocks are the same as NA. You would have to drill and tap the BS cover and simply bolt on the oil filter console/t-stat housing. It wasn't until later that the reinforced case was introduced.
Don Weaver-EBS Racing
don@ebsracing.com
2006 Cayman S
'86 944T
'00 Boxster with EBS Racing 3.4 liter engine
Old 05-04-2010, 11:20 AM
Thank you Guys, I'm think I will just look for a turbo block. I think it will be less complex if stay with turbo parts..
Thank you for all your info on this matter!
Steven
Old 05-15-2010, 05:41 PM
nynor's Avatar
get a late block, then. '88 or later, is my suggestion.
Old 05-15-2010, 07:35 PM
