There is no substitute..
Unknown Wire - HELP
Hi. I changed my sensors and injectors harnesses with LR Harness. While I plugged the reference mark and the speed sensors connectors, I saw a wire that is unplugged. The problem is I dont find the other wire to plug it together.
This is the white wire. He was under some wires but for the picture I moved it to the top ![]() The connection type ![]() Here is where he go. Direct under the reference sensor.. Blue: Reference sensor Green: Speed sensor Red: The unknown wire ![]() Since I have the car.. I dont think this wire had been already plugged.. ![]() I wish to know what is this wire and what he is doing.. ![]() Thanks!!
--Matt I couldn't find the sports car of my dreams, so I built it myself Porsche 951 1988 - More than 305 RWHP & 350 RWTorque |
Rogue Tuning
That is a test sensor for use with diagnostic equipment. It serves no other purpose, and should not be plugged into anything.
-Joshua www.RogueTuning.com |
Heheh thats great to ear
![]() Thanks sir!
Rogue Tuning
No problem
Hey Rogue, maybe you know this:
Question: Tomorrow I will re-install the camshaft housing (assembly). As clarks garage said: If old lifters are to be reused, ensure that all lifters are installed in the same location their were in on removal. Mmm.. I dropped something near the lifters and they are all mixed.. They are no more in the removal order.. Is this can be bad or..!?
Rogue Tuning
Probably be fine. Just make sure the lifters and lifter bores are clean and lubed before re-installing.
Great. Is the lifters are all same!? Because I know its good to keep the order for the metal usure but they dont seems to be very used.
Anyways, what problem can I get if something go wrong!? I will pay attention about that when i'll start the car
Rogue Tuning
They are all the same, though they will wear-match to the cam/bores... Which is why you typically want to keep them in order.
Ok. So I can get in serious trouble or its not the end of the world?
Rogue Tuning
Not the end of the world.
Fioufffff.
