Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
There is no substitute..
FRZ951's Avatar
Unknown Wire - HELP
Hi. I changed my sensors and injectors harnesses with LR Harness. While I plugged the reference mark and the speed sensors connectors, I saw a wire that is unplugged. The problem is I dont find the other wire to plug it together.
This is the white wire. He was under some wires but for the picture I moved it to the top
The connection type
Here is where he go. Direct under the reference sensor..
Blue: Reference sensor
Green: Speed sensor
Red: The unknown wire
Since I have the car.. I dont think this wire had been already plugged..
I wish to know what is this wire and what he is doing..
Thanks!!
--Matt
I couldn't find the sports car of my dreams, so I built it myself
Porsche 951 1988 - More than 305 RWHP & 350 RWTorque
Old 08-19-2011, 12:44 PM
Rogue Tuning
Rogue_Ant's Avatar
That is a test sensor for use with diagnostic equipment. It serves no other purpose, and should not be plugged into anything.
-Joshua
www.RogueTuning.com
Old 08-19-2011, 02:29 PM
FRZ951's Avatar
Heheh thats great to ear
Thanks sir!
--Matt
Old 08-19-2011, 02:42 PM
Rogue Tuning
Rogue_Ant's Avatar
No problem
-Joshua
www.RogueTuning.com
Old 08-19-2011, 02:46 PM
FRZ951's Avatar
Hey Rogue, maybe you know this:
Question: Tomorrow I will re-install the camshaft housing (assembly).
As clarks garage said: If old lifters are to be reused, ensure that all lifters are installed in the same location their were in on removal.
Mmm.. I dropped something near the lifters and they are all mixed.. They are no more in the removal order.. Is this can be bad or..!?
--Matt
Old 08-19-2011, 04:26 PM
Rogue Tuning
Rogue_Ant's Avatar
Probably be fine. Just make sure the lifters and lifter bores are clean and lubed before re-installing.
-Joshua
www.RogueTuning.com
Old 08-19-2011, 04:28 PM
FRZ951's Avatar
Great. Is the lifters are all same!? Because I know its good to keep the order for the metal usure but they dont seems to be very used.
Anyways, what problem can I get if something go wrong!? I will pay attention about that when i'll start the car
--Matt
Old 08-19-2011, 04:39 PM
Rogue Tuning
Rogue_Ant's Avatar
They are all the same, though they will wear-match to the cam/bores... Which is why you typically want to keep them in order.
-Joshua
www.RogueTuning.com
Old 08-19-2011, 04:51 PM
FRZ951's Avatar
Ok. So I can get in serious trouble or its not the end of the world?
--Matt
Old 08-19-2011, 05:07 PM
Rogue Tuning
Rogue_Ant's Avatar
Not the end of the world.
-Joshua
www.RogueTuning.com
Old 08-19-2011, 05:15 PM
FRZ951's Avatar
Fioufffff.
--Matt
Old 08-19-2011, 05:27 PM
