Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
Modified Alternator bracket
I have searched the forums and cannot find the thread on how to modify my alternator bracket to accept the Nissan (?) alternator.....anyone out there have any idea?
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 07-28-2012, 11:26 AM
your average wrencher...
thought it was the alternator you modify to fit...
1982 931 *project*
1986 951 Garrett turbo, Rogue Tuned (sold)
1987 944S chipped, konis, rollbar (traded)
1979 924 total rebuild and blueprinted (sold)
Old 07-30-2012, 08:42 AM
89-944NA's Avatar
No, it's the bracket (alternator mounting lug), it needs to be milled down to fit the narrower mounting lugs of the alternator. There is also a spot on the bracket that needs to be milled for clearance. The thread I saw had all the measurements and the modification you need to make for the plug. I also can't recall if it was a toyota or nissan alternator. It's been over a year since I saw the thread, guess it wasn't on this forum....will try rennlist.
Semper Fi
Old 07-30-2012, 09:58 PM
That Guy
Techno Duck's Avatar
Its a Nissan Quest alternator, pretty sure that thread was on RL also; in the turbo forum.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 07-30-2012, 10:30 PM
Pardon my ignorance, but what's the benefit? Better, cheaper alternator?
86 951 blk
Old 07-31-2012, 04:03 PM
89-944NA's Avatar
With the larger turbo, and MAF, the MAF pipe rests right on the back of the alternator, pushing the MAF up and making it hard to close the hood properly. Also, with the larger turbo, you cannot run the alternator fresh air ducting to keep the alternator cool. Newer alternators aren't a solid case like the 951 alternator, and the Quest alternator also has a higher amp rating.
Added bonus, if the alternator fails out in the middle of Podunk, Oklahoma, I can get a replacement just by walking into any major auto parts store...not so with the stock alternator. And it somewhat cheaper.
Semper Fi
Old 07-31-2012, 06:09 PM
There are a few versions of the alternator case that are specified to fit a Quest. Some of them are better than others to fit the 944 bracket. You have to grind out some material on the bracket below where one of the case screws pokes out roughly halfway between the alternator mounting ears.
Here is the original thread...
Smaller alternator issue completed(pics) - Rennlist Discussion Forums
Old 08-01-2012, 09:35 AM
