Victor Reinz lower gasket rebuild kit
Possible a easy question. What is all included in this kit? I emailed pelican parts and they said they were not sure.
Thanks everyone again! |
Everything but the O-rings for the turbo lubrication (no turbo oil inlet or turbo to engine support O-rings). Balance shaft O-rings and seals, oil pump front seal, rear main seal, oprv seals and O-rings, pan gasket, air/oil separator O-rings, oil cooler/oil cooler block-off seals and gasket...NO water pump gasket.
Thank you!
