Help! Turbo S pulls abruptly to the side on throttle transition.
Basically what the title says. It's most noticeable above 45mph. When the throttle is applied, the car will suddenly pull to the right for a brief moment, and when the throttle is released it will suddenly pull left. The movement is very abrupt and destabilizing (and has gotten worse in the last couple weeks), like the whole weight of the car is shifting from one side to the other.
I recently replaced all 4 shocks with OE Koni yellows (inserts up front), replaced front control arm bushings, steering rack bushings, tie rods, and front wheel bearing (the car needed them all). It helped with most of the handling issues but this one problem seems to persist, and I'm starting to think it's not suspension related. My local mechanic is stumped and I don't have any Porsche/import specialists in my area. Any help in diagnosing this issue would be greatly appreciated. Last edited by Fronkey; 08-27-2015 at 09:35 AM.. |
Something is loose in the rear suspension, causing a change in alignment under torque.
Good luck, George Beuselinck |
I would look at all the of the bushings around the trailing arm. Both the inner end of the banana arm and the main pivot on the outside of the torsion carrier.
Brad Tompkins Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968 |
Could it be a transaxle/CV joint/axle/hub, or tire problem.
I had to replace one tire on the rear due to a puncture on a trip, the old tire was very close to time for replacement and just due to the different tire diameters, I could feel it push when I got on the gas. It surprised me that I could feel the difference.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock |
+1 maybe a tire issue. 10-15 pounds low in right rear...?
Tire pressure
