Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
951 Engine Rebuild question
Hello All,
Does anyone know of a shop that can do the rebuild in California? Car is currently in the San Francisco Bay Area but I do travel to Southern California at least twice a month and can bring it down to the LA area if needed. Whats an average fair cost to do the rebuild? Another option is to search for a complete engine. Not sure which would be the best option.
1986 951 all stock
170,000 miles
Found a small pool of gray oil in one of the cylinder head.
Chambers inside the intake manifold are black and a bit oily.
Car turns over but no throttle response and no smoke from exhaust.
Thanks in advance for any advice.
Old 12-07-2016, 06:09 PM
I am NOT a mechanic, but do stay at Holiday Inn Express on occasion! That being said.........
I'm not clear if the engine starts and runs, if it does, it's quite possible you don't need a complete rebuild. Get someone to do a leakdown test first.
You may just need to have the head refreshed. Assuming you meant the pool of oil is on one of the piston heads, it could be a leaky valve seal or head gasket or both.
Has the turbo ever been rebuilt, that could cause the oil/soot in the intake.
My car only has ~120K on it, but after I did the head and turbo rebuild, she runs like NEW.
Bruce P.
2011 Cayman Base, LSD, Sport Chrono.
1988 951 totaled and missed
"You're the best I ever had" --JJ Cale
Old 12-08-2016, 12:54 PM
At least do compression and leakdown test to establish state of innards. Worn turbo can leak lots of oil. And intake leaks can cause poor throttle response.
There's a 951 engine for sale somewhere for $1200. If you get it, might as well rebuild it. With the age if these cars, any used motor should be rebuilt anyway, just for the seals alone.
Old 12-09-2016, 12:58 AM
Ga 951 and DannoXYZ, thanks for the info. I will do the compression test this weekend.
Old 12-09-2016, 08:23 AM
Hi,
Just bought a 951. I am going to use Comeau Racing in San Diego for my engine overhaul.
/Peter
Old 12-24-2016, 12:23 AM
Pauld_94S2's Avatar
Second to Comeau Racing.
Tim is a racer and has been servicing the 944/924 matrix exclusively for years.
Comeau Racing Enterprises – Your 944’s Best Friend in San Diego!
https://www.facebook.com/Comeau-Racing-Enterprises-CRE-1513071998987188/
Old 12-24-2016, 07:45 AM
Thank you for the suggesting Comeau Racing in San Diego. Does anyone know of a similar place in the San Francisco Bay Area?
Old 12-27-2016, 08:55 AM
170k miles isn't a big deal on the 944 engine.
Might be time for a head gasket/head rebuild along with turbo seals as suggested previously, though.
Old 01-02-2017, 08:57 AM
Is Tim of Fast Lane in Santa Cruz still around?
EDIT: Found info - Fast Lane Porsche Repair
Tim did a emergency radiator repair for me while he still worked at My Porsche-Audi in Monterey. Was able to get back to Laguna Seca overnight.
Old 01-21-2017, 01:24 AM
