Oil return tube issue
I bought this a few years ago and getting time to finally devote to it. When removing the HE I noticed the return tube was slightly crushed.
What is the best way to fix this and what is the easiest. I know one is usually not the same
Old 08-06-2019, 12:53 PM
964TargaC2's Avatar
Our host sells replacements that do not require removing the head, I bought the nice Aluminum Rausch & Speigel ones, a bit of silglide helps get them in
After you have the replacement remove your dented one with pliers, dont cut it off!
I think that maybe I'm dreaming..
Old 08-06-2019, 02:17 PM
If it's not totally crushed and does not leak on both ends, I will not bother replacing it.
Just drive and enjoy, nobody looks down there maybe except you.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 08-07-2019, 06:37 AM
