cmw cmw is offline
993 Billet Engine Cases
Our New 993 Porsche Billet Engine Case getting closer Getting all the proofing done. Along with our new 5.0L Billet Engines coming Soon. Those engines will be available through Redstone Performance Engineering, Contact Garnet @ 317-445-6313 or email redstonePE@gmail.com
CMW Motorsports LLC
6845 Speedway Blvd. Suite K105 • Las Vegas, Nevada • 89115 • (702) 462-9296
www.cmwmotorsports.com
Old 09-11-2018, 01:31 PM
5.0L for a 993 Air-cooled platform?
Old 09-12-2018, 11:36 AM
clutch-monkey's Avatar
is that meant to be 4.0L?
Old 09-13-2018, 03:17 AM
hum...... sub'd
81 SC 3.8 Conversion
2017 Macan S
INSTAGRAM @tail_spinz
Old 09-13-2018, 02:12 PM
cmw cmw is offline
Yes, our 5.0 liter to start will be for the air-cooled platform. But we are making billet cases for both the 993 & Our 5.0 Liter Platform
CMW Motorsports LLC
Old 09-14-2018, 02:28 PM
cmw cmw is offline
I am not sure what your meaning, the 993 billet case goes from stock to 4.2l, the 5.0 liter engine is completely different, looks the same from the outside, they will be set up for upside down fans, billet throttle bodies or slide valves for normally aspirated and turbocharged
CMW Motorsports LLC
Old 09-14-2018, 02:31 PM
MMMM 993 with a 302, I get my Porsche and fox body fix.
Old 09-28-2018, 08:51 AM
Is there another thread on this forum, with a different company also producing billet cases for aircooled 911s?
Old 09-29-2018, 12:58 AM
Ora Ora is offline
Banned
Yes, the people are Home, they got one nifty case in the works.
Samuel.
Old 10-01-2018, 04:26 PM
gearhead
Samuel.
That's not billet. That's an all new casting.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 10-02-2018, 06:38 AM
Chain fence eating turbo
You should post this in the 911 forum too.
People will be chomping at the bit to put a huge motor into an early model!
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 10-02-2018, 08:49 AM
Ora Ora is offline
Banned
Yes indeed not billet, it is heat pressurized to 30K pounds at 900F,and the finish on the case looks fantastic indeed.
Old 10-02-2018, 02:03 PM
Cobalt's Avatar
A quality sand casting should not need the HIP process. HIP was designed to remove trapped gasses in poorly cast aluminum. A356.0T6 is a sand cast alloy. To be MIL spec it needs to comply with ASTM-B-26 or similar and all the requirements otherwise it is an alloy used but isn't MIL spec. HIP will not make a cast part stronger than a cast part that was devoid of gasses to begin with. If gases are present then something is wrong with either the melting process or sand mix. It is actually a cheap fix for lack of QC. Although doesn't hurt.
I would be more interested if they were radiographically or Fluorescent dye penetrant inspected to Class A Grade A or some established criteria to meet MIL spec and if they are certifying these to A356.0T6 or just using A356 heat treating it to T6 which anyone can do. Assuming they meet min criteria of separately cast test bars 24k PSI Yield 34K Ultimate Tensile and 3.5% elongation it should yield a stronger casting than the factory. Although I would expect integrally cast test bars and random sampling of a casting with sub sized bars would be better IMO.
In order to comply with the MIL specs sub sized bars from the casting only need to meet 75% of the requirements of the spec. I regularly saw 32k Yield 42k Tensile and 5% elongation out of sub-sized test bars cut from my castings when properly cast and heat treated. Although that was dependent on the house performing the heat treatment process which is rather complex to do correctly and even many DOD and NADCAP approved houses I knew of cut corners.
I am also curious how they plan to increase displacement? Will it use wider barrels or do they intend to increase the stroke which will require new jugs and heads?
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS,
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others
Old 10-11-2018, 07:03 AM
Wow. I bet you’re lots of fun at parties
Old 09-18-2019, 01:58 PM
Lol, 11 months late with the diss, buddy guy
P/S: anything even come of these cases?
"Frankenstein" - 964 C4 chassis/driveline - 993 widebody/Speedster look - VEMS standalone - twin plug high compression 3.6L N/A engine - 945cc cc/min injectors - Bosch 044 pump - GT45 @ 1bar/14psi - non intercooled/wingless - E85 fuel - turbo inlet water meth inj. - 3.5" exhaust - GT3RS clutch + LWFW
Old 09-18-2019, 02:35 PM
kevinbodman930's Avatar
He maybe late butt the man knows what he's talking about.
Old 09-18-2019, 03:04 PM
