OBD 1 Fault Codes
Does anyone have a chart of fault codes for the OBD 1 diagnostic system? I'm using the blink codes of the check engine light and need to know for sure what a 15 means. The Bentley book shows throttle potentiometer but that seems unrelated to my stall issue.
Thanks!
James S.
Old 09-28-2019, 03:34 PM
I believe 15 relates to Idle Speed Contact, either failed or working intermittantly, if it is an engine fault code. I asume this is the Idle Position mico switch on the left side of the! throttle body linkage. Exactly what car do you have?
Old 09-29-2019, 02:10 AM
Mine is a 1995 911 (993). Early version with OBD 1 pins.
Old 09-29-2019, 03:48 AM
Thanks Paperboy! Let me give you the whole situation and see if you have any ideas. My 1995 993 starts and runs strong until (with a/c on and stop and go driving) it gets hot. The temp gauge is just at normal. Then the car stalls and will not restart until it cools. I changed out the DME relay and that did not change the stall, only cooling and then a restart.
Old 09-29-2019, 04:52 AM
I think the micro switch relates to 964, potentiometer to 993. No expert, you might have checked but does the throttle body mechanism move freely? If that is the case I believe you can reset things by disconnecting the battery, check that the throttle is closed and restart the engine. The ECU will read this position and log this as Throttle Closed position. Any way of removing the potentiometer and measure it or measuring it in place ?
Old 09-29-2019, 05:04 AM
I assume that it works like a lot of other sensors on these cars. It is supplied with 5 volts and sensor position gives 0- 5 volts out which then the ECU translates to a throttle opening degree.
I know electric components can work OK when cold but then start missreading when hot due to expansion, especially if worn.
Old 09-29-2019, 05:21 AM
I would also like to know what the codes are for the 964 and 964 Turbo OBD1 cars. Someone gotta have a list.
Thanks for your help
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 09-30-2019, 11:15 AM
burgermeister's Avatar
The Bentley has a list of some of the codes, 1-5 is not among that list.
Mine flashes 1-5 as well. However, the motor is in a kit car, and a number of things (air injection, AC, heat, blowers, speedometer, etc) are not connected.
A couple of places I have found that list some trouble codes, no idea if they are correct:
https://rennlist.com/forums/993-forum/995719-fault-codes-on-95-993-obdi.htmlhttps://www.troublecodes.net/porsche/
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 10-30-2019, 04:17 PM
