p911dad's Avatar
Secondary Air Injection Check Valve successfully replaced!
After replacing the vacuum cut off valve for the air injection system, I realized the real culprit was the secondary air injection check valve. It took 5 off and on days of using Kroil penetrating oil and an old heat gun to get the check valve out without damaging its manifold or any of the air pipes that lead to each cylinder's exhaust valves. Here's a few photos of the process. The check valve is the brass colored device under the silver colored vacuum cut off valve. You need to remove the airbox to get in here to work. I also pulled the gasoline filter for more room. I know this has been documented before a number of times, but what the heck, something to do in the corona virus lockdown.
This is the top of the air injection manifold with the SAI removed. I unsuccessfully used a dremel tool to cut a notch in the valve and hammering it with a cold chisel to try to get it started turning counterclockwise (failure). I then tried a large Channel lock wrench, again no luck. At this point the valve was really looking beat up. I ended up using a 3/8 socket wrench with a 1 1/16" thin crowfoot and a heat gun (I heated it up to 200 degrees F ). I cranked it using a 2' iron pipe as an extension of the socket wrench, and it finally broke loose.
This is the thin crowfoot I used (I opened it up from 1" to 1 1/16" to fit the valve). I didn't have a 27mm crowfoot, so I used this one. It's an old military surplus item I found on Ebay. I cut the valve open and it was totally corroded inside and rusted over.
Here's the new valve and the old valve. From the outside the old valve looked pretty good.
Here's the crowfoot in action with the socket wrench. I used some thread grease so the valve will come out easily next time it's needed to replace it. I only tightened it a bit, again reasoning I don't want to go through this aggrevation again!
Old 05-08-2020, 01:27 PM
Great job, Its a lot easier on a 965. but I have two of them.
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 05-11-2020, 09:25 PM
david9962000's Avatar
If your 993 is a 95 you can remove the pump and plug it. No check engine light.
https://patrickmotorsports.com/products/eng-993-113-200-aib-pms
Old 05-22-2020, 03:47 PM
Cobalt's Avatar
You can buy those plugs for about $5.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS,
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others
Old 05-26-2020, 06:39 AM
