Engine bracket colors
Hey,
I started to clean the engine area and was cleaning one of the gold colored brackets as seen in the picture and the plate went to an aluminium colour.
I was using a very fine surface cleaner on it. I then tried just WD40 at the lower part and the Aluminium look started to come through?
Now is it that they are aluminium colour and they have just got tarnished over time, or are they plated with a gold color?
If plated it really shouldn't come of so easy.
All comments very welcomed.
Alex
Old 03-01-2022, 10:50 AM
Originally the parts were CAD Plated which gave it the gold appearance and corrosion protection. CAD plating is no longer available but Zinc plating can provide a similar appearance and better protection.
Any mild abrasive will remove the original plating unfortunately, especially if the car was exposed to salt.
CURRENT:
2011 Boxster Spyder, Sport Buckets, MT, Full Leather, PSE, Basalt Black/Black
1990 964 C2, MT, Marine Blue, Silk Grey/Marine Blue
2024 Macan White, Beige / 2010 Cayenne White, Black
PAST: 69 911 Targa, 87 928 MT Marine Blue, 90 928 GT Marine Blue, 90 911 Targa Stone Grey
Old 03-01-2022, 09:04 PM
Cobalt's Avatar
Is that a loose hose clamp sitting there?
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS,
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others
Old 03-02-2022, 06:17 AM
Hey,
Thanks for this and I found one liquid from Germany from
https://www.tifoo.de/gelbchromatierung that seems it could do a good copy of the colour.
I could do quite a lot of coating with this bottle
As for the loose clamp Cobalt mentioned, yes it seems to be missing the plastic clamp of the top.
I am unsure what the name or part number of this is so I can check from Rose Passion to get it.
Cheers
Alex
Old 03-02-2022, 09:54 AM
