Convert g64 trans to RWD
We have been working on a C2 project and would like to use the G64 transmission we have. Has anyone completed converting a G64 trans to RWD? I know the internals of G64 and the G50 are different but is there some trick or kit that can be purchased to make the conversion to RWD? The car is a C2 so the removal of all of the drive line tube shifter fabrication and front axles etc is not an issue
Any help?
Old 12-16-2023, 11:04 AM
Bill Verburg's Avatar
Any help?
As you know the issue is the concentric output shafts, blue shaft to rear yellow to front
and planetary gear set connecting them
Shown here are the differences, stock g50 parts are green
You could remove the planetary gear assembly and weld the shafts together
or replace all the internal g64 parts
Bill Verburg
Old 12-17-2023, 09:26 AM
gearhead
There is a pretty detailed thread on Rennlist on how to do this. It’s not easy.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 12-26-2023, 07:54 AM
Do you have the link from Rennlist?
Old 02-05-2024, 07:21 PM
