Convert g64 trans to RWD
We have been working on a C2 project and would like to use the G64 transmission we have. Has anyone completed converting a G64 trans to RWD? I know the internals of G64 and the G50 are different but is there some trick or kit that can be purchased to make the conversion to RWD? The car is a C2 so the removal of all of the drive line tube shifter fabrication and front axles etc is not an issue
Any help? |
and planetary gear set connecting them![]() Shown here are the differences, stock g50 parts are green ![]() You could remove the planetary gear assembly and weld the shafts together or replace all the internal g64 parts
gearhead
There is a pretty detailed thread on Rennlist on how to do this. It’s not easy.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Do you have the link from Rennlist?
Thanks |
