zdr zdr is offline
964 Turbo problem
Hi - My '92 Turbo is having issues, hoping for some advice on where to start.* The car sat most of the winter, when I took it out a few weeks ago it ran great at first, but then on way home started losing power at lower RPM's, got better above 3k and made it home.* Has been getting worse since then, and now just died.* Gradual worsening of power loss until car just quit running.* Tried to start and tons of blue/grey smoke.* After sitting 5-10 min was able to start it but only drive a few hundred feet, then died again.* Same now at home - will start but only run few minutes and then die.* Recs on what I should be checking?* Fuel system - pump/distributer?* Other?
​​​​​​​Thanks
Old 06-13-2025, 12:56 PM
Cobalt's Avatar
To start I would check that your I/C is sitting properly and that the gasket is in good condition between the I/C and the throttle body.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS,
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others
Old 06-16-2025, 05:04 AM
Great advise Anthony, After checking all the vacuum hoses and the turbo hoses. your warm up reg / fuel pressure reg could be going bad. Bad gas could be an issue too
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 06-16-2025, 11:08 AM
