Question Does this look like the LUK update?
Can anybody tell if this is the updated flywheel? LUK is stamped in the hub as you can see in the photo but it is dual-mass. I was under the impression (possibly mistaken) that only the Freudenburg is dual-mass. What's the straight scoop?
thanks, this board is cool
Louis
'91 C4
Old 07-10-2004, 11:25 PM
That's a LUK, the Freudenberg one has a thin steel washer under the bolts.
Make sure you replace ALL of the worn and suspect parts when re-assembling and only use the Porsche grease.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 07-11-2004, 10:36 AM
Senior Member
john_colasante's Avatar
All 964 and 993 use dual-mass flywheel. Exception '89 Carrera 4 and RS/Cup models.
John Colasante
johnc911@gmail.com
www.cupcar.net
Old 07-12-2004, 08:25 AM
