plymouthcolt's Avatar
Originally Posted by Vandit View Post
Is replacing the center 32mm nut advisable? Also, should I consider using any type of thread lock on the inboard bolts or the center nut? Is so, what type?
Thank you.
No need to replace the nut.
No thread lock on the inboard nuts, but it is advisable to recheck the torque after 25 miles.
Howard
2003 996tt
1997 911 Coupe Artic Silver (sold)
1988 Black 911 Coupe (gone but not forgetten)
Old 06-17-2012, 07:30 AM
Thank you for the write up and detailed pictures
Howard
2003 996tt
Old 06-17-2012, 07:31 AM
bart1's Avatar
I just tried to do this procedure. Step 9 did not work for me. I have a later 95 C4 and Bilstein HD shocks. I could not get the outer joint past my shock. I really only needed to replace the inner boot, so I just did it on the car. Messy and tight job, but went okay.
Old 10-27-2012, 02:12 PM
Rick Lee's Avatar
I think I had my HDs on when I did this the first time and certainly the second time. The trick is that you need a second floor jack underneath the brake rotor or hub to compress the shock just the right amount while the car is already on jack stands. It is definitely doable, as I'm a complete clutz and did it twice. On second thought, I may have taken the tranny out before I removed the CVs the second time, but I know it's doable with the tranny in there.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 10-27-2012, 02:22 PM
bart1's Avatar
Old 10-27-2012, 05:36 PM
Removing axle shaft
Im having hell trying to remove the axle. Does removing the shock will permit more space to get the axle out, I already raised the rotor and suspension the highest possible. I need advise, I'm working on my 1996 Targa.
Cheers
Old 12-07-2012, 06:30 AM
retired
snah's Avatar
Cheers
you may have to lower the suspension slightly to make it work, you'll need to play with it a bit to get it just right to wiggle it out
hans
'98 993 C2S
'97 993 C2 †
Old 12-07-2012, 06:40 AM
963K993's Avatar
Thanks for the write up. I wrapped this job up last night. I'd still be there if I didn't see this DIY.
I also had some trouble getting the boot in place. I hit them lightly with a heat gun which made them much easier to stretch.
Old 09-08-2013, 06:42 AM
How did you get the joint back together? Ive been at it 45 minutes and I came in to relax for a few minutes before I throw it.
Old 04-20-2014, 08:38 AM
Rick Lee's Avatar
Go back and look at my photos on pg. 1. That should point you in the right direction. IIRC, they only go together one way, so you shouldn't be able to mess it up.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 04-20-2014, 09:15 AM
It was helpful to me to keep the axle level & resting on the cv joint like on a workbench or on the floor while reassembling the joints as they do like to puke out the balls. I used the floor so as not to risk one falling off the bench.
1996 MIDNIGHT Blue Grey 993 Carrera
Old 04-20-2014, 06:58 PM
resident samsquamch
sand_man's Avatar
Sub'd! Very nice! Mine had just been serviced before I bought the car, but I'm planning to put the miles on this car, so I'm sure to be revisiting this!
-jeff
Old 04-21-2014, 10:24 AM
I got it after a brief break. Thanks!
Old 04-22-2014, 04:59 PM
Step #12 refers to "Pop off the large metal cap that covers the outside of the inboard CV". I noticed that the kit referenced in this DIY (F-332-924-02) does not exist on Pelican anymore. I'm not sure on the correct kit to use? I purchased the kit number PEL-CV993B1 but it does not contain the large metal cap described in step 12...Is it okay to reuse the old caps?
Also, it looks like the hose clamps used in the PEL-CV993B1 kit are different from the normal CV boot clamps that would require the special CV Boot clamp pliers. Does this seem right?
Thanks guys!
Todd
Old 09-15-2015, 04:58 PM
If the old ones are not damaged from removal, I have reused them.
Old 09-15-2015, 04:59 PM
Thanks jhg41977...I did some additional searching and it appears the hose clamps will work fine too.
Old 09-15-2015, 07:55 PM
No problem.
Old 09-16-2015, 01:06 AM
Suggestions on removing axles and separating axle components.
Thanks for this article - it was really helpful on my 1995 993. 2 comments that may be of use to other readers:
1) The use of a 3-arm puller is definitely helpful in getting the parts off of the axle shaft, as was mentioned on page 1 of this thread. To center the threaded rod of the puller, I used a 1-piece star socket, upside down. The star bit went into the hole in the axle so that it would not slip out of place, and the threaded rod went into the 3/8 drive opening.
2) My car absolutely would not let me remove the axles without partially disassembling the suspension. I jacked the car up, down and sideways and there was not enough clearance around the body of the shock. I therefore followed this article to remove the suspension lower mounts, up to the point where the shock body could be pulled away from the mounts and pushed to the outside of the mount, allowing me then to remove the axle.
Pelican Technical Article: 993 Technical Article:
Old 06-01-2016, 08:28 AM
Excellent write up!
Just completed this on my 95 Cab.
A couple of inputs that might help:
2) I also am without an impact gun. Shade tree solution was to use my floor jack on the end of a breaker bar. 1/4 turn enough that I could then loosen the axle nut manually.
12) Used the edge of a block of wood and hammer to separate the metal covers without scratching/dinging
14) No luck banging with hammer. Took it to local machine shop and they pressed it off ($8.50).
21) Same machine shop let me borrow their boot clamp tool.
26) Half a day of cursing did not help. Same shock interference regardless of jacking of wheel...UNTIL I took car off jacks and only jacked the suspension point of that wheel alone. Made a big difference in the amount of strut compression allowing me just enough clearance to insert the axle.
Old 06-20-2016, 11:18 AM
I am stuck at knocking off the outer shield. Started with the selection of punches, large screwdrivers, it will not move at all. Put some pb blaster around it and left the shaft in the vice for tomorrow...
Old 10-14-2016, 06:16 PM
