964 Ventillation Control
I have a '93 C2 that appears to have a faulty heater controller. What years are compatible with this one? I saw a 996 controller that looked identical, but don't know if it is the same one. These things are pricey, but the 996 one seemed reasonable....
Thanks.
David Nolen
Old 01-05-2005, 02:42 PM
hallo
You need a 964 Unit or a very early 993 , but i think you dont have these in the US ( 94 Model ) ,i have a used 964 Unit ,but the weak Dollar
makes it expensive for you ,maybe too expensive ( 500 $ )
harald
Old 01-05-2005, 03:35 PM
I'm sorry (brain not in gear), the one I was looking at was from a '95 993. Does this one work?
Old 01-05-2005, 04:48 PM
AFJuvat's Avatar
You will need to modify the wiring to get a 993 controller to work
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 01-05-2005, 05:22 PM
colo964's Avatar
If your heater/defroster doesn't blow, try looking at your engine compartment fan fuse. If it is burned, the cabin fans won't turn on.
Old 01-05-2005, 05:31 PM
The 993 controller that will work has a part #( 993.659.047.00) that ends in .00, the 95 and newer 993 climate controllers end in part # .01, and will not work.
-Eric
90 C2
NER/PCA
Old 01-05-2005, 06:44 PM
Thanks for the help with the part number. The blowers (front and back) come on, but both flapper valves stay shut so that I get nice warm rear tires but no warm cabin.
Old 01-06-2005, 05:16 AM
My fans work on heat. In defrost mode the fan dose not go to high speed. Goes to high speed in AC mode. Any ideas?
Old 01-08-2016, 08:48 AM
creaturecat's Avatar
I sent my broken unit to Loren. Almost instant turn-around. works perfectly now.
Systems Consulting...Automotive Electronics
Old 01-08-2016, 10:48 AM
Called System consulting today. He had not seen this problem. Gave me good advice as to how to proceed. Thanks for help.
Old 01-11-2016, 09:59 AM
