CDyson's Avatar
Red face 964 stalling problem
My 1992 C2 3.6 964 runs well generally, but has a stalling problem. During warm-up the car stalls quite often when dipping the clutch and coming to a stop. Sometimes the idle control system seems to just catch it in time. other times it stalls. The car has had no modifications and is well serviced. Any ideas?
Old 01-20-2005, 02:58 PM
91C2wrencher's Avatar
Mine does that occasionaly as well, i just give a little more warm up time and try not to stop for a mile or so .....I think in my case its connected with the weather but can't be sure
1991 964 C2 -SOLD - miss it everyday -
2009 Honda CRV
2007 Audi A4 Quattro - just a sweet personal car -
2000 Land Rover Disco II - lifted
2001 GMC Seirra 1500HD CREWCAB
Old 01-20-2005, 03:31 PM
colo964's Avatar
Check the slack in your throttle cable. It should have enough to click the closed throttle switch that signals to the DME to change programs to idle smoothly.
Old 01-20-2005, 07:48 PM
These intermittent misses are going to lead to frequent stalls and may be indicative to a failing AFS. See the other thread on 964 engine stalling.
get a read out of all the fault codes stored by the OBD1 system in your car.
Old 01-21-2005, 01:43 PM
jc964rs's Avatar
very easy to fix
On the air flow box, the throttle is inked on an axle which goes through the airflow box. Put some WD40 (very light oil) on this axle and each time you start the engine move the throttle several times before you turn the key
you will enjoy a new car !
What can you dream on when owning an RS ?
http://www.ma964rs.com
Old 01-22-2005, 05:09 AM
I'm no expert and I'm a new member with '91 C4 Cab (only ~ 1 1/2 months old to me) with 34,400 original miles.
I was having stalling problems as well when cold & warm! Since my car was basically a garage queen, I assumed that the fuel & air system was not as "clean as it should be". I got approval from my independent Porsche master mechanic to put Chevron Techron fuel injector cleaner (20 oz. - treats 20 gallons) into the gas tank when refilling.
Since doing that, the car has not stalled once! Before that, it was quite embarassing showing my 964 to family & friends with the car stalling quite frequently.
I've always used FI cleaner in all my cars before all oil changes with fantastic results (ie- no problems).
Hope this helps,
Pete
Old 01-22-2005, 09:15 AM
nabfa1's Avatar
Question .....
What did it turn out to be ? Ty
Old 10-29-2014, 08:14 AM
johnhedge's Avatar
Aircon (After market)
I have similar problems but mine have been identified as the lack of engine management when I have the aircon on.
I don't want to hijack this thread but if anyone has a solution I'd be pleased to hear it.
Thanks,
John
Old 10-31-2014, 05:16 PM
one of gods prototypes
bell's Avatar
C2s need to have the adaption set with the Bosch hammer if the battery is ever disconnected/dies.....this is providing the o2 sensor is connected and operating.
Although there are other things that can cause stalling this is one thing that is generally overlooked on this gen 911....
Brought to you by Carl's Jr.
Old 10-31-2014, 07:30 PM
bell's Avatar
And i just noticed this is a 9 year old thread someone bumped up lol
Old 10-31-2014, 07:31 PM
