If you get one that is stuck AND you've totally mutilated it trying everything else (or you want to avoid that bit of fun) then try this:
Take a hammer and steel chisel (sharp enough to cut into the filter rim) and tap the filter rim in the off direction at a slight angle. You just need to get it rotated a 1/2 inch or so and then a regular filter wrench will get it off.
Then take the hammer to the guy who used a wrench to tighten it.
Mark
Old 10-31-2005, 12:45 PM
Longhoods Unite!
PhatRedHead's Avatar
Send a message via AIM to PhatRedHead Send a message via Yahoo to PhatRedHead
long, strong screw driver and a BFH, pound thru oil filter, make big mess, lots of leverage with long screw driver, remove oil filter, waste 5 rags cleaning up oil and replace with new filter, don't over tighten
1970 911T -- Neglected, oil burning problem, batman smoke
1974 914 2.0 Weber'd -- new project!!
**My Wife and I bought our first house in August of 2009, the footprint of the house is just over 1100 sq. ft...my garage is just over 1000 sq. ft. We compromise well **
Old 11-03-2005, 05:36 PM
kang's Avatar
The chisel and/or screw driver ideas are good ones, except that there is no room for either on the engine oil filter on a 993. The filter is in a hole, and you can only access if from the top. There is no way the handle of a wrench can stick out sideways from the filter. Same for a screwdriver. You might be able to get a chisel on the top corner, but I suspect it would just dent or open the filter, making a big mess, and it wouldn’t cause the filter to turn. If you could get the chisel on the base of the filter, it might work, but there is no way to get to the base. Take a look at the filter and you’ll see what I mean:
Here it is by itself:
and here it is with a filter wrench on it:
Downshift
Old 11-04-2005, 08:58 AM
