stevepaa's Avatar
wrong outside temp
My onboard computer thinks its 32 F when it is around 70 F. So my ac will not work. Anyone have an idea on how to fix this? thanks
Old 11-22-2005, 10:10 PM
AFJuvat's Avatar
You have three possibilities for failure.
1. Mixing chamber temp sensor is faulty. There are two of these sensors, located in the top of the HVAC housing. They are long probes. A repair kit is available from Porsche
2. THe interior sensor on your AC control unit is bad. You can get at this by removing the AC control unit.
3. Your control unit itself if bad.
AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 11-25-2005, 07:46 PM
Pingo's Avatar
The outside temp. sensor is located inside the left rear view mirror housing. I don't think the misreading has anything to do with your AC.
2007 Porsche 911 GT3 Club Sport, 1992 RUF RCT EVO, 1980 Porsche 911 SC Targa, 1978 Porsche 911 Turbo, 1968 Porsche 912, 1988 Ferrari Testarossa
Old 11-26-2005, 02:10 AM
AFJuvat's Avatar
I stand corrected, You are correct, I had forgotten about the sonsor in the mirror.
AFJ
Old 11-26-2005, 06:59 AM
stevepaa's Avatar
My outside temp sensor was in the right hand mirror. Strange? Discovered how to remove mirror by tilting the top edge back and using a small screwdriver to rotate the locking ring about 1/4 inch counter clockwise. Pulled the sensor and then put in back in. Now all is well with my temp reading.
thanks for the info
steve
old rocket inguneer
Old 11-28-2005, 08:56 AM
btsave's Avatar
AFJ
Mike,
I have the temp sensor repair kit, (OEM-96461894300 TEMP SENSOR KIT ) but do not see where it goes, can you take a picture of the placement? Thanks!
Bart
Old 07-10-2006, 04:52 PM
