Mark Wilson
Guest
Posts: n/a
CDR 220 install into 993
The stock Becker CDR 210 in Ginger was functional, but I hated the rocker switches. I found a clean CDR 220 out of a 996/Boxster and proceded.
The 210 without faceplate:
I made a couple of removal keys. I won't advocate this cuz you could damage the unit. When the tabs disengage, push the unit from the back:
Disconnect the 3 harness plugs and antenna. I saw a real opportunity to scar the kneepad/dash so I used masking tape on the area around the radio for protection:
For the 220 to fit, you must remove the cage that the 210 sat in. There are 8 tabs (there are 2 different types of tabs) that hold the cage in. Bend them out of the way:
Old 01-29-2006, 08:14 AM
Mark Wilson
Guest
Posts: n/a
There is a green wire connected to the cage that I read is for alarm and not required for the 220. I just disconnected it:
Gathered the connections to plug into the 220:
Sliding the 220 in is a real challenge. It's very difficult to get the wires out of the way and get the back of the unit to seat correctly in the guides. It took 3 attempts for me:
Success! Waiting for the faceplate update from Becker and it's complete:
Send a message via AIM to gamma
Nice upgrade, thanks for the well documented how to. Kevin
Kevin Gildea
71 Alfa
02 R1100s Boxer prep
86 Suzuki RG500
97 993 Cabriolet
06 KTM 625SMC
01 Yamaha WR426
92 KDX 200
85 Yamaha IT 200
Old 01-31-2006, 05:11 AM
kang's Avatar
Excellent info. Do you happen to know if the CDR 210 or 220 can replace the CR-1? E.g. the wiring is the same?
Downshift
Old 01-31-2006, 08:07 AM
Mark Wilson
Guest
Posts: n/a
Kang,
Not sure about the CR 1. I think that was an Alpine unit? May be different plugs. If no one answers here, I bet Rennlist has it in the archives.
Old 01-31-2006, 08:45 AM
kang's Avatar
Thanks Mark. I can't remember off the top of my head if it is an Alpine or a Becker.
Downshift
Old 01-31-2006, 03:08 PM
Alarm not working after cdr 220 install.
Re: I read is for alarm and not required for the 220. I just disconnected it..
I just upgraded to the CDR 220 and did not see a place to connect the alarm wire. Now when I lock the doors, the horn does not chirp. I also got into the car, armed the car and opened the doors but the alarm did not go off any suggestions for the relation to the horn/alarm and the CDR 220 install?
BTW, this radio sounds much better than the 210!
Old 06-22-2010, 10:02 AM
Formerly known as Syzygy
Canada Kev's Avatar
If you only did not connect that green wire and didn't accidentally dislodge something else while you were in there, perhaps just ground that green wire. The original radio cage would have been grounded and if you didn't reconnect that wire, it won't be grounded any longer.
This is just a guess, but it may help.
Kevin
Old 06-23-2010, 05:32 AM
Mark do you still have the CDR210? Please PM me if it is available for purchase.
edit:just realized this thread is 4 years old!
Greg
Old 06-28-2010, 12:31 PM
Which way do the plugs go?
I removed and reinstalled my CR 210 from my 993. Now the radio doesn't see the CD changer. The plug for the CD pulled out when I removed the radio and I didn't see which way it goes in. Does the locking tab go toward the inside or the outside of the radio?
Rex
96 993
72 911
Old 11-16-2011, 11:27 AM
ChaseN's Avatar
In the absence of the sleeve, what holds the 220 in place?
Old 11-19-2011, 06:50 PM
Send a message via AIM to deekay911 Send a message via Skype™ to deekay911
Gravity...
1996 993 C2
1995 968 Cab
1976 Norton 850
Old 11-21-2011, 07:01 AM
