indigowhale's Avatar
Send a message via Yahoo to indigowhale
Porsche Crest Increasing idle on 964 due to stalling
1990 C2 keeps stalling probably due to lightweight flywheel. It does it at lights and stop and go traffic.
Where is the screw to increase the idling RPM, is it the throttle flap stop screw or is there an air bypass screew (in addition to the AFM idle mix screw)? I am supposing that one exists.
Many thanks in advance.
Indigowhale
1990 Carrera 4, 1984 Carrera, 1986 Carrera -
1987 944, 1979 SC, 1969 911T, 1971 914 -
Old 03-28-2006, 06:54 PM
Porsche Junky
mede8er's Avatar
Here's some good info.....
3.6 liter conversion stalling at low speeds
I did the ISV surgery and adjusted it counterclockwise which made the idle tolerable......But for my 993 conversion I ultimately used a Rennsport chipped DME fro Steve Weiner and now my car idles silky smooth....
1986 930 RUF equipped
Old 03-29-2006, 06:21 AM
My 90 C2 was doing the same thing (I also have lightweight flywheel). It took JW about 5 minutes to fix. Turned out that the micro switch on the linkage just needed a minor adjustment
Old 03-29-2006, 08:21 AM
Thanks, that links has all the information I need!
Am I assuming correctly that the ISV is not adjustable from the factory and that a little surgery will make it so?
TIA.
Indigowhale
Old 03-29-2006, 12:25 PM
Bill Verburg's Avatar
Correct, there are 3 x2.5mm(IIRC) hex head bolts buried in epoxy, you will need a dremel to clean out the epoxy.
The 964s have a microswitch which 993s don't have i would start w/ that.
Also check for vacuum leaks
Bill Verburg
Old 03-29-2006, 01:58 PM
