1990 C2 keeps stalling probably due to lightweight flywheel. It does it at lights and stop and go traffic.
Where is the screw to increase the idling RPM, is it the throttle flap stop screw or is there an air bypass screew (in addition to the AFM idle mix screw)? I am supposing that one exists. Many thanks in advance.
Indigowhale 1990 Carrera 4, 1984 Carrera, 1986 Carrera - 1987 944, 1979 SC, 1969 911T, 1971 914 - |
Porsche Junky
Here's some good info.....
3.6 liter conversion stalling at low speeds I did the ISV surgery and adjusted it counterclockwise which made the idle tolerable......But for my 993 conversion I ultimately used a Rennsport chipped DME fro Steve Weiner and now my car idles silky smooth....
1986 930 RUF equipped |
My 90 C2 was doing the same thing (I also have lightweight flywheel). It took JW about 5 minutes to fix. Turned out that the micro switch on the linkage just needed a minor adjustment
Thanks, that links has all the information I need!
Am I assuming correctly that the ISV is not adjustable from the factory and that a little surgery will make it so? TIA.
The 964s have a microswitch which 993s don't have i would start w/ that. Also check for vacuum leaks
