ischmitz's Avatar
Send a message via Skype™ to ischmitz
The infamous Bosch Hammer (aka KTS301) at work (long with pics)
Hi,
I justed wanted to share some pictures of my new Bosch Hammer (aka KTS301) at work on my 3.6 installed in an earlier Targa. It's named after its funny shape. It looks like an L with the LCD display on the short arm of the L and the keypad on the long arm.
First I had to build a diagnostics port. A stock car has a 19-pin AMP socket. The matching connectors where made by AMP as a Porsche special. They are NLA. Well, since I don't care about stock I used an 8pin LEMO socket for this purpuse. They are readily available and sturdy to survive a lifetime. I made a matching cable with a LEMO 8-pin connector on one side and the AMP connector for the hammer on the other. It works just as well and is a lot cheaper.
Next lets switch on the Hammer, it goes through its selftest routine showing the firmware version of the internal CPU
Next it shows the software version of the installed software cartridge. Bosch made several generic versions and a Porsche-only version that was only available to Porsche dealers. The generic versions can do some stuff on the Porsche but not all. Here the latest Porsche-only cartridge is installed. It is version 8.1 in English dated September 1st 1995 (Germany notes the date as dd/mm/yy). This module covers everything up to early 993's.
Next you can choose which vehicle you work on such as 944, 911, 928 etc. Choose 1 for 911 to initiate the communication
The Hammer scans the vehicle bus for installed components. In my case I only have the DME. A stock vehicle would have additional units such as the climate control unit, the ABD, the onboard computer, etc. Here we find one item: 1=DME
The Hammer then reads out the software version of the installed DME and its type information
Next we get into a menu where you can depending on whether the engine is running or not check for actual values or actuate components on the engine. First I read out the fault memory to check whether anything is obviously wrong. It comes back with a clean bill of health.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 05-12-2006, 09:30 AM
ischmitz's Avatar
The actual value menu allows displaying realtime information of various engine conditions such as RPM, ignition timing, temperatures, etc. You can also perform the system adaptation and the knock count from here.
I have choosen to display the head temperature sensor output. It is given in degrees C and F.
I hope this was fun. There is lots you can do with the Bosch Hammer. A failure of a sensor or wiring harness sould be a breeze to diagnose with this. And if you can't find the fault you can still bash the engine using it in its literal sense - as a hammer.....
Cheers,
Ingo
Old 05-12-2006, 09:31 AM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
awesome Ingo...that is a great tool to have to keep the 3.6 doing as it was intended.
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 05-12-2006, 09:43 AM
Administrator
Jack Olsen's Avatar
Thanks, Ingo! Nice to see how it works.
You should sell your port adapters to guys who have done swaps.
Old 05-12-2006, 10:46 AM
Sports Purpose 911 Driver
mjshira's Avatar
Ingo
Great thread and very interesting details. Ditto to Jack's comment, you should sell them, I'd be interested. Can you read CHT on all 6?
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 05-12-2006, 10:50 AM
DByers's Avatar
Thats great Ingo, but how does it help ME with MY tail light problem?
I see your working hard today as usual. Perhaps I need to play hooky the rest of the day.
Dan Byers
Old 05-12-2006, 10:56 AM
defcon65's Avatar
Interesting - would that work on a 3.2 for diagnostics? I read somewhere my 85 Carrera did not have an internal diagnostic computer that would give out codes for faults. Would this tool allow a mechanic to do that kind of diagnostic scan? Sorry if this is a 101 question, I'm not familiar with the technology.
Joe
Joe
85 Carrera
64 Honda Dream - for sale
71 Hodaka Super Rat - keeper
Old 05-12-2006, 11:00 AM
MBEngineering's Avatar
HI would you like me to find you a porsche lead so you can work on other PELICAN cars????
there is no diag' connecter for the 3.2 , i have a porsche 3.2 DME diag' /check book if that is any good?
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Somewhere in the Midwest
MotoSook's Avatar
Cool Ingo. Did you get your hammer from Germany? Is it 120 or 240 VAC?
Old 05-12-2006, 11:02 AM
ischmitz's Avatar
James,
the scanner reads the CHT sensor that is used to determine whether the engine is under cold-start conditions or warmed up. So no, you can "only" read the one sensor that is installed. The tool essentially talks to the Motronic and displays what the Motronic reads. The main reason for being able to read the sensors is to check whether the Motronic sees plausible values.
I might come up with a little something if someone is interested in terms of adapters. To make it really plug and play you would need to get a set (male and female) of the 14pin connector. This carries most of the signals required for the diagnostics port. From there is it simply soldering and assembly work. Short of that you could solder the wires straight to the 14 pin connector of the conversion harness. That is what I did.
Cheers,
Ingo
Old 05-12-2006, 11:03 AM
ischmitz's Avatar
Yes, I got mine from Germany. It came with the standard 220V wall transformer. I made another one for 120 volts from scatch. Now you can use it anywhere.
Old 05-12-2006, 11:04 AM
mjshira's Avatar
thanks Ingo. I might have some interest in that set-up. Once again, nice write-up.
Old 05-12-2006, 11:08 AM
ischmitz's Avatar
regards mike
Mike,
SURE, if I don't have to remorgage my home for one
I know that JDS Porsche in the UK sells reproduction versions of the 19-pin Porsche connector. John is asking something like 80$ for one. I have not seen any original cables for sale in a while.
I think the LEMO solution works just as well. What I really like to get is some male and female 14pin connectors. If someone has a cut-up harness from a 964 or later and could spare these connectors that would be great.
Old 05-12-2006, 11:10 AM
HI i have a hammer and a guy over hear that repairs them i will ring him and try to find one for you, i can get you a car socket from the brakers yard if you won't one??
regards mike
Regards mike
Old 05-12-2006, 11:22 AM
Bill Verburg's Avatar
I'm soooooo jealous
Bill Verburg
Old 05-12-2006, 11:53 AM
ischmitz's Avatar
Mike,
that would be cool. Here is a picture of the 14-pin connector I was talking about. This style is used throughout the later models (964, 993, etc). If I could get a matching pair I would be very thrilled. You can see the cloth side with the exposed wires. This is the DME harness. The side with the electrical tape is my conversion harness. If I get the 14pin male/female combination that would make things cleaner.
Regarding the diagnostics socket and the matching cable for the hammer that would also be very interesting for me. I just heard that the cables are unobtanium. Let me know what you come up with.
Cheers,
Ingo
Old 05-12-2006, 12:06 PM
charleskieffner's Avatar
would be interested for my '87 3.2.
Old 05-12-2006, 12:18 PM
ischmitz's Avatar
Originally posted by Bill Verburg
I'm soooooo jealous
says the guy with TWO hot RS rides and one powered by a 3.8 weapon....
Old 05-12-2006, 01:38 PM
Just trying to be a good Republican
Bill Verburg
Old 05-12-2006, 01:43 PM
DW SD's Avatar
Just curious, how much is a hammer, approximately?
Do you have a schematic of the inputs to the hammer?
Any way to adapt an OBDII code reader?
I know pre '96 is OBDI.
Very cool - thank you for sharing!
1971 RSR - interpretation
Old 05-12-2006, 02:07 PM
