simon.marsh@xtr's Avatar
964 Ambient Temp indicator
My onboard computer always reads 40.0 degrees C no matter what the temperature is. I think the sensor is located in a mirror. Anybody worked on this before?
Simon "Swampy" Marsh
1986 3.2 Carrera Coupe black and beautiful
1991 3.6 964 Coupe Guards Red
1992 3.6 964 Coupe Turbo Look widebody.
2004 3.6 996 Turbo
Old 12-12-2007, 01:41 AM
I have had this also after removing my mirrors and placing them back: also 40 Celsius...
Turned out that I switched the cables/connectors at the sensor in the mirror housing.
Good luck,
Dick911
Old 12-16-2007, 10:27 AM
Sounds Simple, a Christmas job so I can sneak out into the workshop.
2004 3.6 996 Turbo
Old 12-19-2007, 09:27 PM
Drivin' Miss Daisy
benzyne's Avatar
I'm guessing the sensor is in one of the outside mirrors? Can you guys point me in the right direction? My onboard computer has been reading the wrong temps as well, but I did a lot of playing with various things before.
Regards,
Ben
58 VW Split Window Bus - Porsche Powered
78 911SC Turbo Look - Megasquirt II, EDIS, 964 intake
92 964 Turbo
Old 03-17-2009, 07:37 PM
Member
The sensor should be in your left side mirror.
there is a hole in the bottom of the mirror casing for the temp sensor probe to 'feel' the outside air temp.
See if your mirror has this small sensor tip showing in the hole.
Common failures include corroded wiring or connectors in the mirror housing, failed sensors, and incorrect wiring due to aero mirror upgrades.
Paul
91 964 C2 Targa sold (shipped back to the fatherland)
09 Cayman PDK 17 Titan
55 Sunbeam S7 Deluxe
70 Triumph Bonneville
Old 03-18-2009, 07:54 AM
Drivin' Miss Daisy
benzyne's Avatar
fixed. loose connection at the mirror. thanks!
92 964 Turbo
Old 03-18-2009, 11:27 AM
