Turn signal switch hangs up - fix?
Hello my turn signal switch does not return after the turn.
I know these are one unit - steering column switch in 964's, but is there a fix or does the entire switch have to be replaced? Thanks!!! earl
78 SC Coupe 93 RSA (Gone) |
Re: Turn signal switch hangs up - fix?
I found that mine would not lock in one direction or release in the other. What happened was the plastic arm that retains the spring in place broke off. I was able to wedge and epoxy a washer in place to hold the spring where it belonged then it was just a simple rebuild and rivit it back together.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS, Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others |
I just went through this on my 1991 C4. Left turn signal would not cancel, but right worked fine. All that I ended up having to do was adjust the switches out towards the steering wheel a bit, they weren't hitting the cancel lever. Made my day. Good luck.
1991 C4-edging further away from stock 1972 T-Incoming project |
Oh if mine was to be that easy - I have my fingers crossed!
Hopefully will getbto this in shortly - other projects jumped ahead of the line. thanks earl
I took the airbag off (normal safety rules apply), took the steering wheel and column covers off, loosened the bolt that holds the switches on, moved it a little, reassembled and it worked. You could probably get to the bolt without doing all of that, but I was cleaning in there also so I was okay with taking it all apart. Good luck.
Thanks for the details !!! I will look for this as I remove.
Boy I hate rereading my posts - wish there was a editor I could use. Oh well! Thanks Earl
