964 C2 suspension upgrade
I am interested in lower my 1992 964 C@ porsche.
I have a chance to install a stock 1993 RS struts, shocks and springs. Can any one tell me if this a straight crossover fit and if the RS springs will lower my Porsche. Plus can any one tell me if the RS stiffer suspension becomes a rough ride. I would like to increase suspension performance slightly but not to the point of a rough ride since I drive the Porsche on the street 95% of the time. Thanks for any feedback
Best regards Keith 92 964 Coupe 99 Volvo xc70 02 BMW 330xi |
I have a complete RS suspension setup on my 90 C2. I did not do the install myself, but it appeared to be fairly straight forward with the addition of front camber plates. The ride height is adjustable. With 18" wheels, it is definitely a stiff ride; smaller wheels might be better for a street car.
Kris 1990 C2 2005 CS http://krisu.smugmug.com/Auto/Porsche |
This link should give you some answears: http://www.porsche964.co.uk/technical/rs_suspension.htm
On my old 90C2 I ran a Bilstien/H&R ride height adjustable set up. It was a good set up.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
PRO Motorsports
If it's from an RS America, then it won't lower the car.
The RS America ran the same springs in front, and slightly stiffer progressive rate springs in back. The front swaybar was larger, and the rear was the standard one. The struts were Boge Turbo Gas, IIRC. So, if it is from an RSA, not really much of an upgrade.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Spring upgrade
Thanks for the reply.
I had a feeling it would not lower my 964 but just stiffen it Thanks again
Yes, there is a big difference between RS and RSA.
My setup is RS, not RSA.
Sports Purpose 911 Driver
Kris
Can you post some more info? I recently got a 1990 and would like to do this upgrade but I 'heard' that this was not possible on the 1990 cars..? Thanks!
James Shira R Gruppe # 271 1972 911 Coupe 3.8 RS ‘nbr two’ 1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie' 1955 356 Pre A Coupe ‘old red’ 1956 356A Emory speedster build in progress |
At the low end H&R Coil-Over Suspensions and adjustable sways are the way to go, Still not cheap
H&R/Bilstein sport suspension use the factory RS adjustable sways moving up in cost JIC, Pss9 and even further into the stratosphere Moton, Olins etc.
thanks Bill. I will plan for that. I think it will add to the goal I have for the car. tyson tells me the RS sways make a big diff!
I did not go shopping for Euro RS parts; I just happened to come across them used and for a good price. I don't know how they compare to the other options.
