964 C2 suspension upgrade
I am interested in lower my 1992 964 C@ porsche.
I have a chance to install a stock 1993 RS struts, shocks and springs. Can any one tell me if this a straight crossover fit and if the RS springs will lower my Porsche. Plus can any one tell me if the RS stiffer suspension becomes a rough ride. I would like to increase suspension performance slightly but not to the point of a rough ride since I drive the Porsche on the street 95% of the time.
Thanks for any feedback
Best regards
Keith
92 964 Coupe
99 Volvo xc70
02 BMW 330xi
Old 10-29-2006, 11:13 AM
kurquhart's Avatar
I have a complete RS suspension setup on my 90 C2. I did not do the install myself, but it appeared to be fairly straight forward with the addition of front camber plates. The ride height is adjustable. With 18" wheels, it is definitely a stiff ride; smaller wheels might be better for a street car.
Kris
1990 C2
2005 CS
http://krisu.smugmug.com/Auto/Porsche
Old 10-29-2006, 11:22 AM
Pingo's Avatar
This link should give you some answears: http://www.porsche964.co.uk/technical/rs_suspension.htm
Old 10-29-2006, 02:08 PM
Jeff Alton's Avatar
On my old 90C2 I ran a Bilstien/H&R ride height adjustable set up. It was a good set up.
Cheers
www.turn3autosport.com
Old 11-01-2006, 08:57 PM
PRO Motorsports
Tyson Schmidt's Avatar
If it's from an RS America, then it won't lower the car.
The RS America ran the same springs in front, and slightly stiffer progressive rate springs in back. The front swaybar was larger, and the rear was the standard one.
The struts were Boge Turbo Gas, IIRC.
So, if it is from an RSA, not really much of an upgrade.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 11-02-2006, 08:42 AM
Spring upgrade
Thanks for the reply.
I had a feeling it would not lower my 964 but just stiffen it
Thanks again
Best regards
Keith
92 964 Coupe
99 Volvo xc70
02 BMW 330xi
Old 11-02-2006, 09:09 PM
kurquhart's Avatar
Yes, there is a big difference between RS and RSA. My setup is RS, not RSA.
Kris
1990 C2
2005 CS
Old 11-06-2006, 08:27 PM
Sports Purpose 911 Driver
mjshira's Avatar
Kris
Can you post some more info? I recently got a 1990 and would like to do this upgrade but I 'heard' that this was not possible on the 1990 cars..?
Thanks!
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 11-08-2006, 03:29 PM
Bill Verburg's Avatar
At the low end H&R Coil-Over Suspensions and adjustable sways are the way to go, Still not cheap
H&R/Bilstein sport suspension use the factory RS adjustable sways
moving up in cost JIC, Pss9
and even further into the stratosphere Moton, Olins etc.
Bill Verburg
Old 11-08-2006, 04:13 PM
mjshira's Avatar
thanks Bill. I will plan for that. I think it will add to the goal I have for the car. tyson tells me the RS sways make a big diff!
Old 11-08-2006, 07:23 PM
kurquhart's Avatar
Originally posted by mjshira
Kris
Thanks!
I have the springs and dampers from a Euro RS (don't know the year) on my car. They were installed by my mechanic, not me. When I asked him about fitment, he says that rear camber plates / monoballs were required to make them fit; the stock upper bushings will not work. I also have camber plates / monoballs on the front.
I did not go shopping for Euro RS parts; I just happened to come across them used and for a good price. I don't know how they compare to the other options.
Kris
1990 C2
2005 CS
Old 11-08-2006, 08:16 PM
