bigchillcar's Avatar
Question comparing C2's to C4's..
are acceleration figures different? how about from 1995 to 1996..any changes in 'listed' performance with the new varioram? looking at a '95 C2 and '96 C4 and wondering how they compared in book numbers..and 'butt-o-meter' should anyone have any anecdotes..
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 12-28-2006, 12:16 PM
There is very little difference between the book numbers. However, look at these two cars individually, on their own merits, because I'd wager that is probably in better condition than the other and will perform better. In other words, just like identical 69 T-210s, it's possible one will perform better, consume less oil, and generally be a better one to buy compared to the other.
Short story--look for the best example of the 993, not the best model of the 993.
Old 12-28-2006, 04:23 PM
The Varioram car will have a little more oomph in the midrange, you can feel it when it comes on. But overall, the 95 and 96-98 cars are very similar in performance and feel.
There's a difference in feel between the Carrera 4 and the Carrera 2, of course, even though most of the time the C4 is putting 96 percent of its power to the rear wheels. I've had a couple of Carrera 4's and really enjoyed how planted the car feels in the rain (and, yes, the snow, too).
Vic
97 993 C2 cab (for sale)
Old 12-28-2006, 06:54 PM
Mark Wilson
Guest
Posts: n/a
I haven't driven a non vario 993 but there's not a huge HP difference. I can say that when the vario kicks in, it peels your eyelids back. If you end up with a 993, one must do mod is the LPMM. Look that one up on Rennlist.
The AWD on my C4S is really transparent. Most people would never know it was there.
Old 12-28-2006, 08:18 PM
jeff and mark...both sweet as hell C4's. i'm looking at a '96 C4 cab in virginia that's black, but not nearly as pristine as yours, jeff. yours is outa my league right now. i'm looking at a 90-95K miles car..
ryan
Old 12-28-2006, 09:00 PM
Ryan -
Best of luck to you. If you have any questions about that one in Virginia, feel free to PM me. I'd be happy to help out if I can.
Jeff
Old 12-29-2006, 07:46 AM
thanks, jeff...much appreciated. haven't heard back from the guy yet..
ryan
Old 12-29-2006, 08:14 AM
Email reply sent.
Old 12-29-2006, 11:25 AM
Sonic dB's Avatar
bigchill... if you can, try to drive at least several examples of 993s... before you buy one. This advice was given to me when I was looking, and I did drive probably 8 cars.
All were quite different....I purchased the quickest one, the one that felt the best and had the best service records....but without having driven the others, I would have not had a point of reference. It was hard to believe, but like snowflakes...it seems that no two 993s are exactly the same.
Old 12-30-2006, 11:20 AM
sonic..thanks for the depressing news..ha! seriously, here in arkansas (don't know where you are), it's gonna be a challenge to try a lot of different 993's without getting on an airplane.
ryan
Old 12-31-2006, 12:56 PM
looking at a '90 C4 cab with 160k on the clock. this description:
Features: A/C: Front, Cruise Control, Power Locks, Power Steering, Leather Interior, Power Seats, Airbag: Driver, Airbag: Passenger, Alarm, Anti-Lock Brakes, Fog Lights, Power Windows, Alloy Wheels
Selling Points: One of the best kept, 1990 911 C4 Cabrios avail for purchase. Any qualified PORSCHE® authority will tell you that it has 161K hwy mi is anything but negative, considering the very unique service & maintenance history. Most of the less than 10K annually average mi, been put on by the orig Beverly Hills owner, using this beauty to drive down to his practice in the south LA. Serviced exclusively by PORSCHE® authorized dealers, the last, its 150,000 mi service, completed by a CO PORSCHE® dealer. The records show all services incl the 135K mi full service. At 97K mi, the complete clutch assembly was replaced with new parts and seals. Receipts for this very costly repair are on hand with all other receipts. At 104K mi PORSCHE removed the engine, serviced & all seals replaced to eliminate a small leak Since I have been the owner, I had a new alternator installed & the clutch replaced & I had the car lowered by EIBACH & upgraded to the PORSCHE® Turbo Alloy Wheels.
Condition: The interior is in excellent condition. No cracks on the dash and the special order “Supple Leather” still feels very soft. As the pictures show, the exterior is in awesome shape, shimmering from head to toe and truly looks stunning.
all other things being equal, how did the performance of the '90 964 compare with a '95-96 993 model C4? numbers close?
ryan
Old 12-31-2006, 04:12 PM
Ryan -
Instead of considering performance, I would consider reliability of the 964 C4 vs 993 C4. The mechanisms are ~completely~ different!!
Old 12-31-2006, 05:23 PM
anyone care to comment on what jeff says concerning the different awd mechanisms between the 964 and 993 C4's?
ryan
Old 01-01-2007, 03:33 PM
BlueSideUp's Avatar
Send a message via AIM to BlueSideUp
From what I understand the 964 uses a mechanical differential to split the power between the front wheels (39%?) and the rear wheels (61%). The PDAS computer can lock the rear differential if rear slip is detected and also lock the center differential in case of wheel slip. The front differential is open and can not be locked. The center and rear differential can be manually locked using the switch on the center console making it a 50/50 split. If the PDAS computer fails the car is still AWD, just the traction control function is lost. The 964 C4 also has a very high pressure brake system vs. the C2. Because of the high pressure brake system I've heard you need a Bosch Hammer to properly bleed the system.
The 993 system is also mechanical except that slip is controlled using a viscous coupling in the center and rear differential. As the front or rear slips fluid is heated in the viscous coupling which starts to "lock" or transfer power to the other wheels. I think the split was changed to be normally 15% front and 85% rear. This setup is a lot more simple but probably does not work as well in deep snow or sandy conditions.
From what I've read the 964 system tends to induce more understeer while the 993 system is largely transparent. I can't remember if the regular 993 C4 had the high pressure brake system, I know the 993 Turbo did.
There is a great article by Adrian Streather over on Rennlist regarding the C4, that's where I got most of my 964 knowledge.
-Jess
Old 01-01-2007, 06:21 PM
Good explanation, Blue. (Pilot??)
The 993 C4 uses the electro-hydraulically boosted brake system that the turbo uses.
Old 01-01-2007, 06:24 PM
BlueSideUp's Avatar
InTheAir-
Thanks for the info on the C4 brakes, too many numbers in my head!
Yes I am a pilot, my instrument instructor always told me to keep the blue side of the artificial horizon up. Good basic advice!
-Jess
Old 01-02-2007, 01:46 PM
former lear driver here...lear captain for air cargo companies and an air ambo outfit for years. blue side up...good advice..
ryan
Old 01-02-2007, 02:12 PM
Definitely. As long as that vacuum pump is working.
Jeff
Private Pilot
Land/Sea
Instrument Rated
HP/Complex
Old 01-02-2007, 06:41 PM
BlueSideUp's Avatar
Yeah those vacuum pumps can be a pain in the butt. I've only had one fail but it was during IMC on the procedure turn for an ILS! The airplane I fly now uses laser ring gyros that are extremely reliable, the main problem is the screens failing.
Jeff- I like your photos, what kind of equipment are you using?
Big Chill have you found your car yet? I've seen your threads about the 964s, seems like you're specifically looking for cabs. I like the look of the 964 and am in the same price range as you. It's either you find a beat 993 or a nice 964 in the low 20s. I have seen a few good ones go for the high teens.
Have you been able to drive a C4 yet? I've never driven one, just a couple C2s. I would guess it's tough to find a selection in your area.
Jess
ATP
Comm/Inst SEL
MEI
-Jess
Old 01-02-2007, 08:21 PM
jess...you summed up my problem perfectly - beater 993's or decent 964's. i was determined to get a 993, but i just can't do it, so it's gonna be a 964 C4 cab when i find my car. and yeah..arkansas isn't just filled up with p-cars to try out..
ryan
Old 01-03-2007, 07:20 AM
