Send a message via Yahoo to k3racing
Question Squeak in dash
I have a 95 993 Cab, and have started to hear a squeak behind the dash. I was wondering if someone out there could give me some pointers on removing the lower dash so that I can investigate and correct the squeaking problem. I do most of my own work on the car so I'm pretty comfortable to tearing it down.
Thanks for any help.
Old 04-03-2007, 08:04 PM
Don Plumley's Avatar
Pull out the radio and HVAC control unit to see the lower mounting bolts. Side panels on the ends hide the other bolts IIRC.
It's probably worth some time looking around before you start removing the lower dash though. There's a bolt between the dash and console that might be worth looking at.
Don Plumley
M235i
Old 04-04-2007, 08:30 AM
Thanks for the info Don,
I've already been poking around under there and was unable to find anything within plain sight that was obviously loose. I removed several of the instrument gauges, nothing there... removed the ash tray and saw 2 bolts that look like they are for the lower dash (or knee protector as they call it in the manual) but wasn't exactly sure what other bolts were there to hold it in place. I plan to do more probing before I get serious about removing the lower dash but wanted to know how big an effort it was going to be to remove it so I can dig deeper.
Thanks a bunch!
Kevin
Old 04-04-2007, 11:11 AM
Banned
Maybe the Windshield squeaking syndrome? it is fairly common.,Candy.
Old 04-05-2007, 04:24 AM
colo964's Avatar
I had a cricket in my dash. Turned out to be a loose glove box hinge.
Old 04-05-2007, 07:44 AM
kang's Avatar
Is the squeak perhaps located in the passenger airbag doors? There is a TSB for that.
Downshift
Old 04-05-2007, 08:01 AM
Thanks to all the responders!! I'll be looking into it today... I'll let you know what I find.
Thanks again. Kevin
Old 04-07-2007, 08:46 AM
bigchillcar's Avatar
my squeak in the dash is on the passenger side. it's one of the blower fans for the interior with failing bearings. you can easily check this by cycling your 'defrost' switch if you have one like on a 964.
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 04-08-2007, 08:27 AM
Thanks to all!! Fixed it!! A bundle of stereo cables were loose and just needed to be tightened and secured.... cricket is GONE!!
Old 04-16-2007, 07:46 PM
