Manassas, VA
lucittm's Avatar
Need Tutorial On How To Remove Rear Bumper
I have a 1991 964 and I need access to the turbo mounting plates. It appears the best way to wrench on the flange nuts is to remove the rear bumper. A cursory review of this and the "other" forum do not offer any suggestions.
Can someone who has recently done this walk me through the steps for a rear bumper R&R?
Thanks,
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 07-03-2007, 07:23 PM
group911@aol.co's Avatar
I comes off in one piece. There are 3 8mm head screws that connect the bumper to the quarters on each side. There are 2 phillips head screws per side that attach the tubular brackets in the wheel wells.
Remove the right side exhaust tip and you will see a large 10mm allen head bolt. Remove that and one on the opposite side and the whole assembly will come off.
Have a blanket under it to avoid scratching the paint.
Also, the license plate light wiring connects from the right side and you will have to deal with it before removal.
Thanks,
Bob
group911@aol.com
Old 07-04-2007, 06:02 PM
