Converting to new refrigerant
i've got a 92 C2 cab and the A/C has quit...ALL servos work....the lines look like they are good shape....do i have to change the gaskets to accept the new refrigerant? or should it work in all the factory lines.....i know that R 134a (i think that's the name) is different than the old stuff and heard it's hard on the lines.....any truth to that?
There are many threads on R-12 to R-134 refrigerant on the main tech forum. If your system is good, you are largely better off staying with R-12. The conversion isn't really hard on the lines (it's just refrigerant), but it is harder on the compressor. You should also change oil and flush the system, replace the receiver/dryer.
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
i thought it was illegal to sell R 12.....if not where can i find it?
It is illegal to manufacture new R-12. It can be recovered, reprocessed and sold by licensed AC techs. And it is spendy. So you really want to make sure you system does not leak before recharging it.
thanks
Thread Tools | |
Rate This Thread | |
