'91 C2 Cab
Bottom spark plug change
All,
I changed the top plugs in my 964 and have not yet attempted the bottom. How much of the exhaust do I have to remove to get to them? Does it all have to be removed at the manifold, or can it come apart in pieces? It appears I have to remove the side panels of the engine box too....... Is this a blind procedure like a valve adjustment? Thanks ~Jeff
'91 C2 cab 50K miles box stock, driver, just not daily. "I never cease being dumbfounded by the unbelievable things people believe." Leo Rosten |
You should not have to remove the exhaust AFIK. Removing the engine tin on the right side helps. But easier on a 964 than a 993...
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
For the 964 you have to remove the catalyst and resonator. This should be done with valve adjustment. Make sure you do a leakdown and compression test if this car is new to you or has never been done.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
'91 C2 Cab
Thank you, that is what I thought after looking at the job.
Lower Spark Plug Change
I replaced my 12 plugs on 1990 964 a few weeks ago. For the bottom, I had to remove the engine shield, secondary muffler and the catalytic converter. Also the fiber/heat sheild covers on each side. None of this is very difficult. Easiest to use a lift, but jack stands or ramps work. You'll need a long extension, and a socket that grips the plugs well. I find the uppers are harder to change (especially the right front and left rear) due to inaccessibility. The whole process
took me about 4 hours. |
Do you have any fotos of this?
i recently changed the top plugs but was a little lost when i tried to do the bottom. i looked at the manual but theres very little in it. Thanks |
